混凝土热力耦合分析错误?
浏览:2204 回答:2
Degree of freedom 11 and at least one of degrees of freedom 1 thru 6 must be active in the model for *coupled temp-disp. Check the procedure and element types used in this model.
Invalid load type on element 1 instance part-1-1. Load type r is not valid for element type c3d8r
这个怎么修改模型??
