ABAQUS新手急需帮助
浏览:4536 回答:1
4508 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
Integration and section point output variables will not be output for deformable elements that are declared as rigid using the *rigid body option
Output request s is not available for element type conn3d2
Output request svavg is not available for element type conn3d2
Output request svavg is not available for element type c3d8r
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are no such jumps. All jumps in displacements across steps are ignored
警告提示,无法运行作业怎么办
why_0948
应该是约束条件设置的不正确,再去检查一下约束
2023年4月20日
