求助!lsdyna出现这个问题,一直卡住不往后计算了,请问该怎么解决?
浏览:3471 回答:1
Beginning of keyword reader                                   03/10/25 15:53:06
 Memory required to process keyword     :    31636524
 *** Warning 21131 (STR+1131)
     Space dimension for SPH set to 3D (IDIM changed from 0 to 3)
 input of data is completed
 initial kinetic energy = 0.00000000E+00
 The LS-DYNA time step size should not exceed     1.546E+01
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 Memory required to begin solution      :      90M
 Additional dynamically allocated memory:     119M
                                   Total:     209M
 initialization completed
     Message 40538 (SOL+538) exceeds 50 times
     Further printing will be suppressed from screen only
 Summary of warning messages for interface #   = 1
   number of warning messages                  = 489432
       1 t 0.0000E+00 dt 1.61E+00 flush i/o buffers            03/10/25 15:55:45
       1 t 0.0000E+00 dt 1.61E+00 write d3plot file            03/10/25 15:55:45
求助!lsdyna出现这个问题,一直卡住不往后计算了,请问该怎么解决?的图1
到这里就不动了
汴京抓鱼人
网格转化过程中粒子密度不匹配,先换个简单材料本构排除下基本错误。
2025年3月12日
评论 点赞 1
