求助,这是什么问题呀,几分钟就莫名中断? 20
浏览:3751 回答:2
 Command line options: i=cut_hole_stem_full2_6221RHT.k
                       NCPU=24
 Input file: cut_hole_stem_full2_6221RHT.k
 The native file format       : 32-bit small endian
 Memory size from default     :   100000000,            0
 Memory option                : AUTO selected
 Memory size from default     :   100000000,    100000000
 Memory for the head node
 Memory installed (MB)        :       191730
 Memory available (MB)        :       182431
 allocating  memory to   100000000 d         672 Initial allocation
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LST nor the authors assume any responsibility for  *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. Users must verify their own     *
 * results.                                                   *
 * LST endeavors to make the LS-DYNA code as complete,        *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LST through your site focus.                *
 * Copyright (C) 1990-2021                                    *
 * by Livermore Software Technology, LLC                      *
 * All rights reserved                                        *
LSTC Environment Variables:
LSTC_MEMORY=auto
LSTC_LICENSE=ansys
 Beginning of keyword reader                                   08/21/23 19:15:34
 expanding   memory to   182533160 d    47161142
 *** Warning 70025 (OTH+25) (processor # 0)
     Memory is set 82533160 words short
     increase the memory size to 182533160
 expanding   memory to   192672780 d    47161142
     Memory is set 10139620 words short
     increase the memory size to 192672780
 expanding   memory to   192702780 d    47161142
     Memory is set 30000 words short
     increase the memory size to 196672780
 expanding   memory to   192762780 d    47161142
 expanding   memory to   192783846 d    47161142
 expanding   memory to   192804478 d    47161142
 expanding   memory to   233356958 d    47161142
     Memory is set 36684178 words short
     increase the memory size to 233356958
 expanding   memory to   273909438 d    47161142
     Memory is set 40552480 words short
     increase the memory size to 273909438
 expanding   memory to   273931638 d    47161142
     Memory is set 22200 words short
     increase the memory size to 277909438
 expanding   memory to   274046638 d    47161142
********** echo of pfile data **********
*********** end of pfile data **********
 expanding   memory to   279301556 d    47161142
     Memory is set 1392118 words short
     increase the memory size to 281909438
 expanding   memory to   284540602 d    47161142
     Memory is set 2631164 words short
     increase the memory size to 285909438
 expanding   memory to   342170108 d    47161142
     Memory is set 56260670 words short
     increase the memory size to 342170108
 expanding   memory to   347409154 d    47161142
     Memory is set 5239046 words short
     increase the memory size to 347409154
 expanding   memory to   352648200 d   138395222
     increase the memory size to 352648200
 *** Warning 11199 (KEY+1199)
     DCT should be -1 in *CONTROL_ALE
 *** Warning 10989 (KEY+989)
     AFAC not equal to -1 in *CONTROL_ALE invokes ALE smoothing
     which is not supported for MPP versions. Please turn it off
     if set up by accident.
 *** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 2
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 2 with
     MATERIAL ID 2 and
     EOS ID 2
     This is PART 2 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 3
     PART ID 3 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 3 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 4
     PART ID 4 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 4 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 5
     PART ID 5 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 5 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 6
     PART ID 6 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 6 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 7
     PART ID 7 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 7 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 8
     PART ID 8 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 8 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 9
     PART ID 9 with
     MATERIAL ID 4 and
     EOS ID 0
     This is PART 9 in the order of input.
 expanding   memory to   357716770 d   138395242
     Memory is set 5068570 words short
     increase the memory size to 357716770
 expanding   memory to   362785330 d   138395242
     Memory is set 5068560 words short
     increase the memory size to 362785330
 Memory required to process keyword     :  362785330
 Additional dynamic memory required     :  138395242
 allocating  memory to   362785330 d    47161162 end of keyword reader
 MPP execution with       2 procs
 LS-DYNA will perform a structural only analysis
 Initial reading of file                                       08/21/23 19:16:04
 LS-DYNA keyword deck by LS-PrePost
                         ls-dyna mpp.190 s              date 10/29/2021
 expanding   memory to        5493 d         748 material, node and element data
 expanding   memory to        5599 d         750 mat add general damage 0
 expanding   memory to        5689 d         750 material added airbag porosity leakage
 expanding   memory to        5725 d         750 material properties
 expanding   memory to        5752 d    60995011 element data for composite material
 expanding   memory to        5767 d   238269123 gradient of damage data
 expanding   memory to        6005 d   238269126 user control for contact interfaces
 contracting memory to        5994 d   238269126 thermal expansion 0
 expanding   memory to        6003 d   238269126 state of charge expansion 0
 expanding   memory to        6005 d   238269126 cross-sectional force definitions 0
 expanding   memory to     5245051 d   238269180 temp index array for node sorting
 contracting memory to        6005 d   243508230 just because?
 expanding   memory to     5074565 d   253986394 arbitrary element numbering input
 *** Warning 20037 (STR+37)
     Input contains 8 ALE parts.
     Please use the keyword below to avoid potential problem.
     *CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS
 contracting memory to        6006 d   290017031 process element material data
 expanding   memory to        8007 d   290017022 load curve data
 contracting memory to        6013 d   290017022 user_define_loading_set
 expanding   memory to        6213 d   290017022 regularize time history data
 contracting memory to        6017 d   290017022 *DEFINE_ELEMENT_DEATH
 expanding   memory to        6581 d   325539181 contact interfaces
 expanding   memory to        7581 d   773737792 contact segment data 1
 expanding   memory to    56273199 d   773737792 contact segment data 3
 contracting memory to        6581 d   778976838 contact definition
 expanding   memory to        6662 d   778976839 rigid body
 expanding   memory to        6666 d   778977913 contact friction
 expanding   memory to        6801 d   778977913 joints
 expanding   memory to      611473 d   778978513 non-reflecting silent boundary 1
 expanding   memory to    16063224 d   778978513 non-reflecting silent boundary 3
 contracting memory to      611573 d   778978513 rigid bodies for disp. termination
 expanding   memory to      611582 d   816888492 ale reference system
 expanding   memory to      611734 d   816888492 ALE fsi control block
 expanding   memory to      611743 d   827366584 ALE fsi node and seg list
 expanding   memory to      611745 d  3215083135 ALE fsi coupling forces
 expanding   memory to      611823 d  3215083135 ALE storage for coupling shape functions
 expanding   memory to    21568181 d  3209673603 void materials
 expanding   memory to    21568190 d  3214912649 mat add cohesive 0
 expanding   memory to    21568199 d  3214912649 flexible body 2
 Performing Decomposition -- Phase 1                           08/21/23 19:17:01
 expanding   memory to    66573244 d    81612045 decomp reverse connectivity
 expanding   memory to    91916044 d    81612045 element ownership
Decomposition region 1:
   Everything
Region  1 is distributed to 2 processors
   With no coordinate transformation
Normalized element costs assigned during decomposition:
            Minumum: 9.999746E-01
            Maximum: 1.000026E+00
 Standard Deviation: 2.542677E-05
 contracting memory to    76880851 d    86851093 constraint scratch
 expanding   memory to    76880852 d    92090139 shadow node processing
 expanding   memory to    82119901 d    86851093 share node processing
 contracting memory to    41605456 d    81612047 nodal sharing list
 Memory required for decomposition      :   91916044
 Additional dynamic memory required     :       3290m
 allocating  memory to   100000000 d    35995004 Allocate memory top of decomps
 expanding   memory to     1000001 d    35995004 hex ownership chunk
 expanding   memory to     1500880 d    35995004 hex ownership chunk
 expanding   memory to     2000768 d    35995004 hex ownership chunk
 expanding   memory to     2500656 d    35995004 hex ownership chunk
 expanding   memory to     2999421 d    35995004 hex ownership chunk
 contracting memory to     2567889 d    35995004 hex ownership chunk
 contracting memory to     1000001 d    38529285 hex sort chunk
 expanding   memory to     1500880 d    38529285 hex sort chunk
 expanding   memory to     2000768 d    38529285 hex sort chunk
 expanding   memory to     2500656 d    38529285 hex sort chunk
 expanding   memory to     2999421 d    38529285 hex sort chunk
 contracting memory to     2567889 d    38529285 hex sort chunk
 contracting memory to          10 d    35995006 material sort chunk
 expanding   memory to          28 d    35995006 material uid
 expanding   memory to          31 d    46609298 nodal force sharing lists 1
 Performing Decomposition -- Phase 2                           08/21/23 19:17:04
 expanding   memory to          40 d    41506421 mat scratch
 expanding   memory to          41 d    45142966 tied nodes scratch
 expanding   memory to          42 d    45142966 tied node scratch
 contracting memory to          40 d    45142966 nodal rigid body scratch
 expanding   memory to       75624 d    45142966 non-reflecting boundary scratch
 contracting memory to          49 d    45142966 tied ale scratch
 expanding   memory to     2609329 d    45142966 ale solid coupling scratch
 contracting memory to          14 d  3255086762 ALE message buffers
 expanding   memory to          18 d  3255086762 ALE message buffers 2
 expanding   memory to     2704643 d  3255086762 ALE share node
 Performing Decomposition -- Phase 3                           08/21/23 19:17:09
 expanding   memory to     2710135 d  3259257603 material, node and element data
 expanding   memory to     2710241 d  3259257605 mat add general damage 0
 expanding   memory to     2710331 d  3259257605 material added airbag porosity leakage
 expanding   memory to     2710367 d  3259257605 material properties
 expanding   memory to     2710394 d  3287238009 element data for composite material
 expanding   memory to     2710409 d  3379004710 gradient of damage data
 expanding   memory to     2744704 d  3417018927 user control for contact interfaces
 contracting memory to     2744693 d  3417018927 thermal expansion 0
 expanding   memory to     2744702 d  3417018927 state of charge expansion 0
 expanding   memory to     2744704 d  3417018927 cross-sectional force definitions 0
 expanding   memory to     5381248 d  3417018981 temp index array for node sorting
 contracting memory to     2744704 d  3417018981 just because?
 expanding   memory to     5278985 d  3422292096 arbitrary element numbering input
 contracting memory to     2744705 d  3434963538 d3thdt storage
 expanding   memory to     2744706 d  3573321066 process element material data
 expanding   memory to     2746707 d  3573321057 load curve data
 contracting memory to     2744713 d  3573321057 user_define_loading_set
 expanding   memory to     2744913 d  3573321057 regularize time history data
 contracting memory to     2744717 d  3573321057 *DEFINE_ELEMENT_DEATH
 expanding   memory to     2744797 d  3573321058 MPP copy of tim vector
 expanding   memory to     2745361 d  3591082145 contact interfaces
 expanding   memory to     2746361 d  4147387540 contact segment data 1
 expanding   memory to    30930241 d  4147387540 contact segment data 3
 contracting memory to     2745361 d  4200118420 contact definition
 expanding   memory to     2745442 d  4200118421 rigid body
 expanding   memory to     2745469 d  4200118421 rbe2 scratch
 contracting memory to     2745446 d  4200118832 contact friction
 expanding   memory to     2745581 d  4200118841 joints
 expanding   memory to     3039757 d  4200119441 non-reflecting silent boundary 1
 expanding   memory to     3039857 d  4200119441 rigid bodies for disp. termination
 expanding   memory to     3039919 d  4200119441 save d3plot control data
 expanding   memory to     3039928 d  4219163968 ale reference system
 expanding   memory to     3040080 d  4219163968 ALE fsi control block
 expanding   memory to     3040089 d  4224437056 ALE fsi node and seg list
 expanding   memory to     3040091 d  5416646181 ALE fsi coupling forces
 expanding   memory to     3040169 d  5416646181 ALE storage for coupling shape functions
 expanding   memory to    13586519 d  5411373097 void materials
 expanding   memory to    13586528 d  5408770595 mat add cohesive 0
 expanding   memory to    13586537 d  5408770595 flexible body 2
 expanding   memory to    18859626 d  5408770595 weld node list 1
 expanding   memory to    18927704 d  5408770595 weld node list 2
 contracting memory to    16223083 d  5408770595 global pointers for welds
 contracting memory to    13586538 d  5408770595 global shared weld node list 1
 expanding   memory to    13620578 d  5408770595 global shared weld node list 2
 expanding   memory to    13620611 d  5596404347 mpp general scratch
 S t o r a g e   a l l o c a t i o n
 Memory required to begin solution      :      31M
 Additional dynamically allocated memory:    5602M
                                   Total:    5633M
 100 smallest timesteps
 element       number                part    timestep
 solid        1146615                   6  7.3510E-02
 solid        1146587                   6  7.3510E-02
 solid        1145527                   6  7.3510E-02
 solid        1145499                   6  7.3510E-02
 solid        1105627                   6  7.3510E-02
 solid        1105599                   6  7.3510E-02
 solid        1104539                   6  7.3510E-02
 solid        1104511                   6  7.3510E-02
 solid        1064639                   6  7.3510E-02
 solid        1064611                   6  7.3510E-02
 solid        1063551                   6  7.3510E-02
 solid        1063523                   6  7.3510E-02
 solid        1023651                   6  7.3510E-02
 solid        1023623                   6  7.3510E-02
 solid        1022563                   6  7.3510E-02
 solid        1022535                   6  7.3510E-02
 solid         982663                   6  7.3510E-02
 solid         982635                   6  7.3510E-02
 solid         981575                   6  7.3510E-02
 solid         981547                   6  7.3510E-02
 solid         941675                   6  7.3510E-02
 solid         941647                   6  7.3510E-02
 solid         940587                   6  7.3510E-02
 solid         940559                   6  7.3510E-02
 solid         900687                   6  7.3510E-02
 solid         900659                   6  7.3510E-02
 solid         899599                   6  7.3510E-02
 solid         899571                   6  7.3510E-02
 solid         859699                   6  7.3510E-02
 solid         859671                   6  7.3510E-02
 solid         858611                   6  7.3510E-02
 solid         858583                   6  7.3510E-02
 solid         818711                   6  7.3510E-02
 solid         818683                   6  7.3510E-02
 solid         817623                   6  7.3510E-02
 solid         817595                   6  7.3510E-02
 solid         777723                   6  7.3510E-02
 solid         777695                   6  7.3510E-02
 solid         776635                   6  7.3510E-02
 solid         776607                   6  7.3510E-02
 solid         736735                   6  7.3510E-02
 solid         736707                   6  7.3510E-02
 solid         735647                   6  7.3510E-02
 solid         735619                   6  7.3510E-02
 solid         695747                   6  7.3510E-02
 solid         695719                   6  7.3510E-02
 solid         694659                   6  7.3510E-02
 solid         694631                   6  7.3510E-02
 solid         654759                   6  7.3510E-02
 solid         654731                   6  7.3510E-02
 solid         653671                   6  7.3510E-02
 solid         653643                   6  7.3510E-02
 solid         613771                   6  7.3510E-02
 solid         613743                   6  7.3510E-02
 solid         612683                   6  7.3510E-02
 solid         612655                   6  7.3510E-02
 solid         572783                   6  7.3510E-02
 solid         572755                   6  7.3510E-02
 solid         571695                   6  7.3510E-02
 solid         571667                   6  7.3510E-02
 solid         531795                   6  7.3510E-02
 solid         531767                   6  7.3510E-02
 solid         530707                   6  7.3510E-02
 solid         530679                   6  7.3510E-02
 solid         490807                   6  7.3510E-02
 solid         490779                   6  7.3510E-02
 solid         489719                   6  7.3510E-02
 solid         489691                   6  7.3510E-02
 solid         449819                   6  7.3510E-02
 solid         449791                   6  7.3510E-02
 solid         448731                   6  7.3510E-02
 solid         448703                   6  7.3510E-02
 solid         408831                   6  7.3510E-02
 solid         408803                   6  7.3510E-02
 solid         407743                   6  7.3510E-02
 solid         407715                   6  7.3510E-02
 solid         367843                   6  7.3510E-02
 solid         367815                   6  7.3510E-02
 solid         366755                   6  7.3510E-02
 solid         366727                   6  7.3510E-02
 solid         326855                   6  7.3510E-02
 solid         326827                   6  7.3510E-02
 solid         325767                   6  7.3510E-02
 solid         325739                   6  7.3510E-02
 solid         285867                   6  7.3510E-02
 solid         285839                   6  7.3510E-02
 solid         284779                   6  7.3510E-02
 solid         284751                   6  7.3510E-02
 solid         244879                   6  7.3510E-02
 solid         244851                   6  7.3510E-02
 solid         243791                   6  7.3510E-02
 solid         243763                   6  7.3510E-02
 solid         203891                   6  7.3510E-02
 solid         203863                   6  7.3510E-02
 solid         202803                   6  7.3510E-02
 solid         202775                   6  7.3510E-02
 solid         162903                   6  7.3510E-02
 solid         162875                   6  7.3510E-02
 solid         161815                   6  7.3510E-02
 solid         161787                   6  7.3510E-02
       1 t 0.0000E+00 dt 7.35E-02 flush i/o buffers            08/21/23 19:17:34
       1 t 0.0000E+00 dt 7.35E-02 write d3plot file            08/21/23 19:17:34
 *** Note history variables in lsprepost --> Fcomp -->misc
     history variable        1 to        3 belongs to AMMG        1
     history variable        4 to       14 belongs to AMMG        2
     history variable       15 to       25 belongs to AMMG        3
     history variable       26 to       36 belongs to AMMG        4
     history variable       37 to       47 belongs to AMMG        5
     history variable       48 to       58 belongs to AMMG        6
     history variable       59 to       69 belongs to AMMG        7
     history variable       70 to       76 belongs to AMMG        8
message里的内容到这里就没有了
求助,这是什么问题呀,几分钟就莫名中断?的图1mes0000.txt
和hypermesh一起发癫
有找到问题吗?我的和你的一样
2025年3月4日
