LSDYNA求解失败,出现下面问题,怎么解决?
浏览:3066
Beginning of keyword reader 11/27/24 11:27:58
*** Error 10246 (KEY+246)
line contains improperly formatted data
reading *DEFINE_CURVE card.
There is an illegal TAB character at column 10
At line# 653 of file
D:\lunwen\11.27\11.24.k
0 0
*** Error 10450 (KEY+450)
in keyword command:
20.20202 ,0.00514
At line# 654 of file
*** Warning 10435 (KEY+435)
lines being skipped - See messag or d3hsp files
*** Error 10133 (KEY+133)
input data failed with: 3 errors
E r r o r t e r m i n a t i o n 11/27/24 11:28:14
Memory required to complete solution : 13M
Additional dynamically allocated memory: 7544K
Total: 21M
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Keyword Processing ... 1.6000E+01 100.00 1.6312E+01 99.78
KW Reading ......... 1.0000E+01 62.50 9.5270E+00 58.28
KW Writing ......... 1.0000E+00 6.25 7.1000E-01 4.34
Initialization ....... 0.0000E+00 0.00 3.6000E-02 0.22
T o t a l s 1.6000E+01 100.00 1.6348E+01 100.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 16 seconds ( 0 hours 0 minutes 16 seconds)
CPU time per zone cycle = 0.000 picoseconds
Clock time per zone cycle= 0.000 picoseconds
Number of CPU's 0
NLQ used/max 136/ 136
Start time 11/27/2024 11:27:58
End time 11/27/2024 11:28:14
Elapsed time 16 seconds for 0 cycles using 0 SMP thread
( 0 hour 0 minute 16 seconds)
