全部悬赏
发布悬赏
专家入驻
LT.0.0: User defined failure subroutine, matusr_24 in dyn21.F, is called to determine failure
EQ.0.0: Failure is not considered. This option is recommended if failure is not of interest since many calculations will be saved.
GT.0.0: Effective plastic strain to failure. When the plastic strain reaches this value, the element is deleted from the calculation.
小于零 是用户自定义失效
等于零 不失效
大于零等于 失效塑性应变
是的,塑性应变
是的,控制材料失效的一种方式,应变失效
是的
¥499
免费
¥9.9
¥99
¥10
¥25
¥30
¥90
小于零 是用户自定义失效
等于零 不失效
大于零等于 失效塑性应变
