Ls-Dyna求解报错? 50
浏览:3531 回答:1
1、
Warning 10177 (KEY+177)
     nodal rigid body and part share the same ID 282
2、
Warning 30313 (INI+313)
     Number of warning messages for rigid bodies
     Have a principal inertia at least 4 orders of magnitude apart=         728
     2-noded nodal rigid body is deleted due to massless node     =           0
     Nodal rigid body deleted due to null inertia tensor          =           0
3、
*** Warning 30131 (INI+131)
     total number of massless nodes = 148
 total nodal rigid body mass= 8.4466144E-04
鲸鱼和月亮
这些只是警告信息,算例可以计算
2018年8月26日
