LS-DYNA做爆破数值模拟,运行k文件后1分钟左右无故终止?
浏览:3714 回答:4
      Date: 08/20/2023      Time: 21:43:43
     ___________________________________________________
     |  Livermore Software Technology, LLC             |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Date    : 10/29/2021    Time: 15:50:06         |
     |  Version : mpp s R12                            |
     |  Revision: R12.1-190-gadfcdf9018                |
     |  Features enabled in this version:              |
     |    Distributed Memory Parallel                  |
     |    FFTW (multi-dimensional FFTW Library)        |
     |    ANSYSLIC enabled                             |
     |  Licensed to:                                   |
     |  Issued by  : ANSYS                             |
     |  Platform   : Intel-MPI 2018 Xeon64             |
     |  OS Level   : Linux CentOS 7.8 uam              |
     |  Compiler   : Intel Fortran Compiler 16.0 SSE2  |
     |  Hostname   : node0993                          |
     |  Precision  : Single precision (I4R4)           |
     |  Unauthorized use infringes LSTC copyrights     |
 Command line options: i=cut_hole_stem_full2_621.k
                       NCPU=96
 Input file: cut_hole_stem_full2_621.k
 The native file format       : 32-bit small endian
 Memory size from default     :   100000000,            0
 Memory option                : AUTO selected
 Memory size from default     :   100000000,    100000000
 Memory for the head node
 Memory installed (MB)        :       191730
 Memory available (MB)        :       188070
 allocating  memory to   100000000 d         672 Initial allocation
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LST nor the authors assume any responsibility for  *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. Users must verify their own     *
 * results.                                                   *
 * LST endeavors to make the LS-DYNA code as complete,        *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LST through your site focus.                *
 * Copyright (C) 1990-2021                                    *
 * by Livermore Software Technology, LLC                      *
 * All rights reserved                                        *
LSTC Environment Variables:
LSTC_MEMORY=auto
LSTC_LICENSE=ansys
 Beginning of keyword reader                                   08/20/23 21:43:43
 expanding   memory to   226731080 d    59137811
 *** Warning 70025 (OTH+25) (processor # 0)
     Memory is set 126731080 words short
     increase the memory size to 226731080
 expanding   memory to   239326140 d    59137811
     Memory is set 12595060 words short
     increase the memory size to 239326140
 expanding   memory to   239356140 d    59137811
     Memory is set 30000 words short
     increase the memory size to 243326140
 expanding   memory to   239416140 d    59137811
 expanding   memory to   239437206 d    59137811
 expanding   memory to   239457838 d    59137811
 expanding   memory to   289832078 d    59137811
     Memory is set 46505938 words short
     increase the memory size to 289832078
 expanding   memory to   340206318 d    59137811
     Memory is set 50374240 words short
     increase the memory size to 340206318
 expanding   memory to   340228518 d    59137811
     Memory is set 22200 words short
     increase the memory size to 344206318
 expanding   memory to   340343518 d    59137811
********** echo of pfile data **********
*********** end of pfile data **********
 expanding   memory to   346929178 d    59137811
     Memory is set 2722860 words short
     increase the memory size to 348206318
 expanding   memory to   353498966 d    59137811
     Memory is set 5292648 words short
     increase the memory size to 353498966
 expanding   memory to   425766624 d    59137811
     Memory is set 72267658 words short
     increase the memory size to 425766624
 expanding   memory to   432336412 d    59137811
     Memory is set 6569788 words short
     increase the memory size to 432336412
 expanding   memory to   438906200 d   172470851
     increase the memory size to 438906200
 *** Warning 11199 (KEY+1199)
     DCT should be -1 in *CONTROL_ALE
 *** Warning 10989 (KEY+989)
     AFAC not equal to -1 in *CONTROL_ALE invokes ALE smoothing
     which is not supported for MPP versions. Please turn it off
     if set up by accident.
 *** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 2
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 2 with
     MATERIAL ID 2 and
     EOS ID 2
     This is PART 2 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 3
     PART ID 3 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 3 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 4
     PART ID 4 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 4 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 5
     PART ID 5 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 5 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 6
     PART ID 6 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 6 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 7
     PART ID 7 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 7 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 8
     PART ID 8 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 8 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 9
     PART ID 9 with
     MATERIAL ID 4 and
     EOS ID 0
     This is PART 9 in the order of input.
 expanding   memory to   445202490 d   172470871
     Memory is set 6296290 words short
     increase the memory size to 445202490
 expanding   memory to   451498770 d   172470871
     Memory is set 6296280 words short
     increase the memory size to 451498770
 Memory required to process keyword     :  451498770
 Additional dynamic memory required     :  172470871
 allocating  memory to   451498770 d    59137831 end of keyword reader
 MPP execution with       2 procs
 LS-DYNA will perform a structural only analysis
 Initial reading of file                                       08/20/23 21:44:19
 LS-DYNA keyword deck by LS-PrePost
                         ls-dyna mpp.190 s              date 10/29/2021
 expanding   memory to        5493 d         748 material, node and element data
 expanding   memory to        5599 d         750 mat add general damage 0
 expanding   memory to        5689 d         750 material added airbag porosity leakage
 expanding   memory to        5725 d         750 material properties
 expanding   memory to        5752 d    75830672 element data for composite material
 expanding   memory to        5767 d   297834873 gradient of damage data
 expanding   memory to        6005 d   297834876 user control for contact interfaces
 contracting memory to        5994 d   297834876 thermal expansion 0
 expanding   memory to        6003 d   297834876 state of charge expansion 0
 expanding   memory to        6005 d   297834876 cross-sectional force definitions 0
 expanding   memory to     6575792 d   297834930 temp index array for node sorting
 contracting memory to        6005 d   304404721 just because?
 expanding   memory to     6302285 d   317544367 arbitrary element numbering input
 *** Warning 20037 (STR+37)
     Input contains 8 ALE parts.
     Please use the keyword below to avoid potential problem.
     *CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS
 contracting memory to        6006 d   362364144 process element material data
 expanding   memory to        8007 d   362364135 load curve data
 contracting memory to        6013 d   362364135 user_define_loading_set
 expanding   memory to        6213 d   362364135 regularize time history data
 contracting memory to        6017 d   362364135 *DEFINE_ELEMENT_DEATH
 expanding   memory to        6581 d   406490565 contact interfaces
 expanding   memory to        7581 d   964188604 contact segment data 1
 expanding   memory to    70087182 d   964188604 contact segment data 3
 contracting memory to        6581 d   970758391 contact definition
 expanding   memory to        6662 d   970758392 rigid body
 expanding   memory to        6666 d   970759466 contact friction
 expanding   memory to        6801 d   970759466 joints
 expanding   memory to      975681 d   970760066 non-reflecting silent boundary 1
 expanding   memory to    20259139 d   970760066 non-reflecting silent boundary 3
 contracting memory to      975781 d   970760066 rigid bodies for disp. termination
 expanding   memory to      975790 d  1018408604 ale reference system
 expanding   memory to      975942 d  1018408604 ALE fsi control block
 expanding   memory to      975951 d  1031548178 ALE fsi node and seg list
 expanding   memory to      975953 d  4715874954 ALE fsi coupling forces
 expanding   memory to      976031 d  4715874954 ALE storage for coupling shape functions
 expanding   memory to    27255353 d  4709031660 void materials
 expanding   memory to    27255362 d  4715601447 mat add cohesive 0
 expanding   memory to    27255371 d  4715601447 flexible body 2
 Performing Decomposition -- Phase 1                           08/20/23 21:47:00
 expanding   memory to    82945688 d   101564628 decomp reverse connectivity
 expanding   memory to   114427088 d   101564628 element ownership
Decomposition region 1:
   Everything
Region  1 is distributed to 2 processors
   With no coordinate transformation
Normalized element costs assigned during decomposition:
            Minumum: 9.979068E-01
            Maximum: 1.002093E+00
 Standard Deviation: 2.093136E-03
 contracting memory to    95811756 d   108134417 constraint scratch
 expanding   memory to    95811757 d   114704204 shadow node processing
 expanding   memory to   102381547 d   108134417 share node processing
 contracting memory to    52048440 d   101564630 nodal sharing list
 Memory required for decomposition      :  114427088
 Additional dynamic memory required     :       4810m
 allocating  memory to   100000000 d    44898107 Allocate memory top of decomps
 expanding   memory to     1000001 d    44898107 hex ownership chunk
 expanding   memory to     1497026 d    44898107 hex ownership chunk
 expanding   memory to     1998751 d    44898107 hex ownership chunk
 expanding   memory to     2494526 d    44898107 hex ownership chunk
 expanding   memory to     2990301 d    44898107 hex ownership chunk
 expanding   memory to     3497139 d    44898107 hex ownership chunk
 contracting memory to     3293829 d    44898107 hex ownership chunk
 contracting memory to     1000001 d    48046247 hex sort chunk
 expanding   memory to     1497026 d    48046247 hex sort chunk
 expanding   memory to     1998751 d    48046247 hex sort chunk
 expanding   memory to     2494526 d    48046247 hex sort chunk
 expanding   memory to     2990301 d    48046247 hex sort chunk
 expanding   memory to     3497139 d    48046247 hex sort chunk
 contracting memory to     3293829 d    48046247 hex sort chunk
 contracting memory to          10 d    44898107 material sort chunk
 expanding   memory to          28 d    44898107 material uid
 expanding   memory to          31 d    58186262 nodal force sharing lists 1
 Performing Decomposition -- Phase 2                           08/20/23 21:47:04
 expanding   memory to          40 d    51765039 mat scratch
 expanding   memory to          41 d    56068502 tied nodes scratch
 expanding   memory to          42 d    56068502 tied node scratch
 contracting memory to          40 d    56068502 nodal rigid body scratch
 expanding   memory to      121150 d    56068502 non-reflecting boundary scratch
 contracting memory to          49 d    56068502 tied ale scratch
 expanding   memory to     4033849 d    56068502 ale solid coupling scratch
 contracting memory to          14 d  5019217502 ALE message buffers
 expanding   memory to          18 d  5019217502 ALE message buffers 2
 expanding   memory to     3377757 d  5019217502 ALE share node
 Performing Decomposition -- Phase 3                           08/20/23 21:47:11
 expanding   memory to     3383249 d  5024669120 material, node and element data
 expanding   memory to     3383355 d  5024669122 mat add general damage 0
 expanding   memory to     3383445 d  5024669122 material added airbag porosity leakage
 expanding   memory to     3383481 d  5024669122 material properties
 expanding   memory to     3383508 d  5059455034 element data for composite material
 expanding   memory to     3383523 d  5174298570 gradient of damage data
 expanding   memory to     3420916 d  5221520672 user control for contact interfaces
 contracting memory to     3420905 d  5221520672 thermal expansion 0
 expanding   memory to     3420914 d  5221520672 state of charge expansion 0
 expanding   memory to     3420916 d  5221520672 cross-sectional force definitions 0
 expanding   memory to     6724378 d  5221520726 temp index array for node sorting
 contracting memory to     3420916 d  5221520726 just because?
 expanding   memory to     6569056 d  5228127677 arbitrary element numbering input
 contracting memory to     3420917 d  5243868414 d3thdt storage
 expanding   memory to     3420918 d  5388426406 process element material data
 expanding   memory to     3422919 d  5388426397 load curve data
 contracting memory to     3420925 d  5388426397 user_define_loading_set
 expanding   memory to     3421125 d  5388426397 regularize time history data
 contracting memory to     3420929 d  5388426397 *DEFINE_ELEMENT_DEATH
 expanding   memory to     3421009 d  5388426398 MPP copy of tim vector
 expanding   memory to     3421573 d  5410489613 contact interfaces
 expanding   memory to     3422573 d  6047828913 contact segment data 1
 expanding   memory to    38518079 d  6047828913 contact segment data 3
 contracting memory to     3421573 d  6113898153 contact definition
 expanding   memory to     3421654 d  6113898154 rigid body
 expanding   memory to     3421681 d  6113898154 rbe2 scratch
 contracting memory to     3421658 d  6113898565 contact friction
 expanding   memory to     3421793 d  6113898574 joints
 expanding   memory to     3906233 d  6113899174 non-reflecting silent boundary 1
 expanding   memory to     3906333 d  6113899174 rigid bodies for disp. termination
 expanding   memory to     3906395 d  6113899174 save d3plot control data
 expanding   memory to     3906404 d  6137821909 ale reference system
 expanding   memory to     3906556 d  6137821909 ALE fsi control block
 expanding   memory to     3906565 d  6144428833 ALE fsi node and seg list
 expanding   memory to     3906567 d  7984442292 ALE fsi coupling forces
 expanding   memory to     3906645 d  7984442292 ALE storage for coupling shape functions
 expanding   memory to    17120667 d  7977835372 void materials
 expanding   memory to    17120676 d  7974569047 mat add cohesive 0
 expanding   memory to    17120685 d  7974569047 flexible body 2
 expanding   memory to    23727610 d  7974569047 weld node list 1
 expanding   memory to    23801884 d  7974569047 weld node list 2
 contracting memory to    20424149 d  7974569047 global pointers for welds
 contracting memory to    17120686 d  7974569047 global shared weld node list 1
 expanding   memory to    17157824 d  7974569047 global shared weld node list 2
 expanding   memory to    17157857 d  8246167087 mpp general scratch
 S t o r a g e   a l l o c a t i o n
 Memory required to begin solution      :      39M
 Additional dynamically allocated memory:    8253M
                                   Total:    8292M
 100 smallest timesteps
 element       number                part    timestep
 solid        1146615                   6  7.3510E-02
 solid        1146587                   6  7.3510E-02
 solid        1145527                   6  7.3510E-02
 solid        1145499                   6  7.3510E-02
 solid        1105627                   6  7.3510E-02
 solid        1105599                   6  7.3510E-02
 solid        1104539                   6  7.3510E-02
 solid        1104511                   6  7.3510E-02
 solid        1064639                   6  7.3510E-02
 solid        1064611                   6  7.3510E-02
 solid        1063551                   6  7.3510E-02
 solid        1063523                   6  7.3510E-02
 solid        1023651                   6  7.3510E-02
 solid        1023623                   6  7.3510E-02
 solid        1022563                   6  7.3510E-02
 solid        1022535                   6  7.3510E-02
 solid         982663                   6  7.3510E-02
 solid         982635                   6  7.3510E-02
 solid         981575                   6  7.3510E-02
 solid         981547                   6  7.3510E-02
 solid         941675                   6  7.3510E-02
 solid         941647                   6  7.3510E-02
 solid         940587                   6  7.3510E-02
 solid         940559                   6  7.3510E-02
 solid         900687                   6  7.3510E-02
 solid         900659                   6  7.3510E-02
 solid         899599                   6  7.3510E-02
 solid         899571                   6  7.3510E-02
 solid         859699                   6  7.3510E-02
 solid         859671                   6  7.3510E-02
 solid         858611                   6  7.3510E-02
 solid         858583                   6  7.3510E-02
 solid         818711                   6  7.3510E-02
 solid         818683                   6  7.3510E-02
 solid         817623                   6  7.3510E-02
 solid         817595                   6  7.3510E-02
 solid         777723                   6  7.3510E-02
 solid         777695                   6  7.3510E-02
 solid         776635                   6  7.3510E-02
 solid         776607                   6  7.3510E-02
 solid         736735                   6  7.3510E-02
 solid         736707                   6  7.3510E-02
 solid         735647                   6  7.3510E-02
 solid         735619                   6  7.3510E-02
 solid         695747                   6  7.3510E-02
 solid         695719                   6  7.3510E-02
 solid         694659                   6  7.3510E-02
 solid         694631                   6  7.3510E-02
 solid         654759                   6  7.3510E-02
 solid         654731                   6  7.3510E-02
 solid         653671                   6  7.3510E-02
 solid         653643                   6  7.3510E-02
 solid         613771                   6  7.3510E-02
 solid         613743                   6  7.3510E-02
 solid         612683                   6  7.3510E-02
 solid         612655                   6  7.3510E-02
 solid         572783                   6  7.3510E-02
 solid         572755                   6  7.3510E-02
 solid         571695                   6  7.3510E-02
 solid         571667                   6  7.3510E-02
 solid         531795                   6  7.3510E-02
 solid         531767                   6  7.3510E-02
 solid         530707                   6  7.3510E-02
 solid         530679                   6  7.3510E-02
 solid         490807                   6  7.3510E-02
 solid         490779                   6  7.3510E-02
 solid         489719                   6  7.3510E-02
 solid         489691                   6  7.3510E-02
 solid         449819                   6  7.3510E-02
 solid         449791                   6  7.3510E-02
 solid         448731                   6  7.3510E-02
 solid         448703                   6  7.3510E-02
 solid         408831                   6  7.3510E-02
 solid         408803                   6  7.3510E-02
 solid         407743                   6  7.3510E-02
 solid         407715                   6  7.3510E-02
 solid         367843                   6  7.3510E-02
 solid         367815                   6  7.3510E-02
 solid         366755                   6  7.3510E-02
 solid         366727                   6  7.3510E-02
 solid         326855                   6  7.3510E-02
 solid         326827                   6  7.3510E-02
 solid         325767                   6  7.3510E-02
 solid         325739                   6  7.3510E-02
 solid         285867                   6  7.3510E-02
 solid         285839                   6  7.3510E-02
 solid         284779                   6  7.3510E-02
 solid         284751                   6  7.3510E-02
 solid         244879                   6  7.3510E-02
 solid         244851                   6  7.3510E-02
 solid         243791                   6  7.3510E-02
 solid         243763                   6  7.3510E-02
 solid         203891                   6  7.3510E-02
 solid         203863                   6  7.3510E-02
 solid         202803                   6  7.3510E-02
 solid         202775                   6  7.3510E-02
 solid         162903                   6  7.3510E-02
 solid         162875                   6  7.3510E-02
 solid         161815                   6  7.3510E-02
 solid         161787                   6  7.3510E-02
       1 t 0.0000E+00 dt 7.35E-02 flush i/o buffers            08/20/23 21:47:37
       1 t 0.0000E+00 dt 7.35E-02 write d3plot file            08/20/23 21:47:37
 *** Note history variables in lsprepost --> Fcomp -->misc
     history variable        1 to        3 belongs to AMMG        1
     history variable        4 to       14 belongs to AMMG        2
     history variable       15 to       25 belongs to AMMG        3
     history variable       26 to       36 belongs to AMMG        4
     history variable       37 to       47 belongs to AMMG        5
     history variable       48 to       58 belongs to AMMG        6
     history variable       59 to       69 belongs to AMMG        7
     history variable       70 to       76 belongs to AMMG        8
mess000文件里的内容就到此没有了,没看到明显的ERROR,请教大家,这是哪个环节出问题了
卢超旭
兄弟你解决了,我现在遇到了和你一样的问题。我流固耦合用的ALE里面的FSI,终止时间是0.1,试了很多办法也只能跑到0.043。msage内容和你差不多的。
2023年11月28日
评论 2 点赞 1
Z_zzz
主要查看smallest timesteps这个信息 看一下这些出现小的单元步长是什么原因导致的 可以看一下动画哪里出现的异常 多半是材料、加载方式、网格质量等问题
2025年3月14日
