dyna在计算sph模拟的流固耦合问题时,总是中止计算,是什么原因?
浏览:2791 回答:1
Input file: G:\sph\1.k
 The native file format       : 32-bit small endian
 Memory size from command line:   100000000
 Binary file                  : 32 bit IEEE selected
 expanding   memory to   100000000 starting ls-dyna
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Finite Element code.                   *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2009                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
 contracting memory to           1 beginning of keyword reader
 expanding   memory to       21002
 expanding   memory to      126706
 expanding   memory to      171706
 expanding   memory to      201706
 expanding   memory to      406402
 expanding   memory to      428084
 expanding   memory to      480316
 expanding   memory to      532548
 expanding   memory to      553301
 *** Warning extra card found in *CONTACT read
             The following card will be ignored.
             Each Contact definition must start with a
             *CONTACT_... card
             *CONTACT_... card
             *CONTACT_... card
 expanding   memory to      574401
 expanding   memory to      594401
 expanding   memory to      614401
 expanding   memory to      634701
 expanding   memory to      654701
 expanding   memory to      681219
 expanding   memory to      879435
 expanding   memory to      903551
 expanding   memory to      956243
 expanding   memory to      978741
 expanding   memory to     1000741
 expanding   memory to     1046418
 Memory required to process keyword     :      1046418
 contracting memory to           1 end of keyword reader
 LS-DYNA will perform a structural only analysis
                         ls-dyna ls971s.50638 R4.2    date 02/04/2009
 expanding   memory to        2833 material, node and element data
 expanding   memory to        2920 material properties
 expanding   memory to       91801 element data
 expanding   memory to      249626 gradient of damage data
 expanding   memory to      707968 user control for contact interfaces
 expanding   memory to      707973 for boundary cond. vectorization
 expanding   memory to      720006 arbitrary element numbering input
 *** Warning warpage angle of element 2136129 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2136130 is 2.9004E+01 degrees
 *** Warning warpage angle of element 2136131 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2136132 is 2.9031E+01 degrees
 *** Warning warpage angle of element 2136148 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2136149 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2136150 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2136151 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2140129 is 2.8989E+01 degrees
 *** Warning warpage angle of element 2140130 is 2.9004E+01 degrees
 *** Warning warpage angle of element 2140131 is 2.9007E+01 degrees
 *** Warning warpage angle of element 2140132 is 2.9009E+01 degrees
 *** Warning warpage angle of element 2140148 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2140149 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2140150 is 2.9010E+01 degrees
 *** Warning warpage angle of element 2140151 is 2.9010E+01 degrees
 *** Warning Number of elements exceed warpage angle =          16
             min warpage angle                       = 0.2898871E+02
             max warpage angle                       = 0.2903063E+02
 expanding   memory to      787246 spc cards
 expanding   memory to     1181451 process element material data
 expanding   memory to     1183457 load curve data
 contracting memory to     1182077 regularize time history data
 contracting memory to     1182077 rigidwall definitions
 expanding   memory to     1215114 nodal constraint sets
 expanding   memory to     1216333 contact interfaces
 expanding   memory to     1250369 implicit contact 1
 expanding   memory to     1250371 implicit contact 2
 expanding   memory to     1525043 contact segment data 1
 expanding   memory to     1642991 contact segment data 2
 expanding   memory to     1763113 contact segment data 3
 expanding   memory to     2502086 contact definition
 expanding   memory to     2552084 rigid body
 expanding   memory to     2931438 contact friction
 expanding   memory to     2945388 rigid body b.c.
 expanding   memory to     3323694 joints
 contracting memory to     3323694 shell solid interfaces
 expanding   memory to     3835753 SPH elements
 expanding   memory to     3847638 discrete element
 contracting memory to     3847638 accelerometers
 expanding   memory to     3847738 rigid bodies for disp. termination
 contracting memory to     3847738 transformation to move nodes
 expanding   memory to     3847746 contact data
 expanding   memory to     3850008 contact data
 expanding   memory to     3850012 thermal expansion 0
 expanding   memory to     3850016 flexible body 2
 contracting memory to     3850016 implicit joints
 expanding   memory to     3898248 initialization phase
        slave surface of interface   =   2000153
        type                         =       a 3
        surface timestep             = 6.573E-05
        controlling slave node ID    =   6081274
        part ID of slave node        =   2000804
        current minimum time step    = 6.573E-05
        master surface of interface  =   2000153
        type                         =       a 3
        surface timestep             = 2.838E-05
        controlling master node ID   =   4320934
        part ID of master node       =   2000805
        current minimum time step    = 2.838E-05
        slave surface of interface   =   2000145
        type                         =       a 3
        surface timestep             = 1.000E+16
        controlling slave node ID    =     12024
        part ID of slave node        =   2327507
        master surface of interface  =   2000145
        type                         =       a 3
        controlling master node ID   =     12024
        part ID of master node       =   2327507
        slave surface of interface   =   2000154
        type                         =       a 5
        surface timestep             = 1.251E+02
        controlling slave node ID    =   6364249
        master surface of interface  =   2000154
        type                         =       a 5
        slave surface of interface   =   2000139
        type                         =        13
        controlling slave node ID    =   4320934
        part ID of slave node        =   2000805
 The LS-DYNA time step size should not exceed     2.838E-05
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 s t o r a g e   a l l o c a t i o n
 Memory required to begin solution      :      3898248
 Additional dynamically allocated memory:      1081800
                                   Total:      4980048
LYH333
有可能是NMNEIGH邻域粒子数太大,调小一些。
或者是FORM里面的算法选择的不对。
再就是平滑长度的两个选项调整一下
2025年6月29日
