ABAQUS 渗流分析时,出现这种问题,最终导致不收敛而中止。该怎么解决好呢??? 20
浏览:2756 回答:1
There is zero VOL. FLUX everywhere in the model based on the default criterion. please check the value of the average VOL. FLUX during the current iteration to verify that the VOL. FLUX is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero VOL. FLUX.
星辰_北极星
这是警告信息,不是导致不收敛的主因。
2018年7月6日
已采纳 评论 点赞
