ABAQUS想问问下面警告什么意思? 10
浏览:3724
There is zero VOL. FLUX everywhere in the model based on the default criterion. please check the value of the average VOL. FLUX during the current iteration to verify that the VOL. FLUX is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero VOL. FLUX.
