浏览:3650 回答:1
* ANSYS 2021 R1 LEGAL NOTICES *
* Copyright 1971-2021 ANSYS, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of ANSYS, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* ANSYS, Inc. is a UL registered *
* ISO 9001:2015 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
Date: 04/30/2024 Time: 22:44:16
___________________________________________________
| Livermore Software Technology, LLC |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Date : 10/29/2021 Time: 15:50:06 |
| Version : smp s R12 |
| Revision: R12.1-190-gadfcdf9018 |
| Features enabled in this version: |
| Shared Memory Parallel |
| FFTW (multi-dimensional FFTW Library) |
| Interactive Graphics |
| ANSYSLIC enabled |
| MADYMO indirect coupling (7.2 or higher) |
| Licensed to: |
| Issued by : ANSYS |
| Platform : WINDOWS X64 (SSE2) |
| OS Level : Windows 8/10 & Srv 2016/2019 uam |
| Compiler : Intel Fortran XE 2017 MSVC++ 2017 |
| Hostname : BJ-20230611WWVA |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Command line options: i=E:\Users\Administrator\Desktop\Shangbin\Structure.k
ncpu=32
memory=1000m
Input file: E:\Users\Administrator\Desktop\Shangbin\Structure.k
The native file format : 32-bit small endian
Memory size from command line: 1000000000
Memory option : AUTO selected
allocating memory to 1000000000 d 544 Initial allocation
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LST nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. Users must verify their own *
* results. *
* LST endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LST through your site focus. *
* Copyright (C) 1990-2021 *
* by Livermore Software Technology, LLC *
* All rights reserved *
Beginning of keyword reader 04/30/24 22:44:16
expanding memory to 565432040 d 173915466
expanding memory to 596843820 d 173915466
expanding memory to 596873820 d 173915466
expanding memory to 596933820 d 173915466
expanding memory to 596954082 d 173915466
expanding memory to 722613524 d 173915466
expanding memory to 848254644 d 173915466
expanding memory to 848276968 d 173915466
expanding memory to 848391968 d 173915466
*** Warning 11080 (KEY+1080)
*RIGIDWALL_GEOMETRIC_FLAT ID 2 has length less than or equal to 0.0
LENL = 0.0000E+00; LENM = 0.0000E+00;
expanding memory to 848417636 d 173915466
expanding memory to 867745310 d 173915470
expanding memory to 887068184 d 173915470
expanding memory to 906401062 d 173915470
expanding memory to 925723940 d 173915470
expanding memory to 1138275598 d 173915470
*** Warning 70025 (OTH+25)
Memory is set 138275598 words short
increase the memory size to 1138275598
expanding memory to 1157598480 d 173915470
Memory is set 19322882 words short
increase the memory size to 1157598480
expanding memory to 1176921358 d 456598993
Memory is set 19322878 words short
increase the memory size to 1176921358
expanding memory to 1176943658 d 456598993
Memory is set 22300 words short
increase the memory size to 1180921358
expanding memory to 1192648300 d 456598999
Memory is set 11726942 words short
increase the memory size to 1192648300
expanding memory to 1208352940 d 456598999
Memory is set 15704640 words short
increase the memory size to 1208352940
Memory required to process keyword : 1208m
Additional dynamic memory required : 456599007
contracting memory to 1 d 173915476 end of keyword reader
LS-DYNA will perform a structural only analysis
ls-dyna smp.190 s date 10/29/2021
expanding memory to 2777 d 610 material, node and element data
expanding memory to 2855 d 624 mat add general damage 0
expanding memory to 2875 d 624 material added airbag porosity leakage
expanding memory to 2883 d 624 material properties
expanding memory to 2889 d 239189503 element data for composite material
expanding memory to 2903 d 4741419054 gradient of damage data
expanding memory to 2977 d 4976988685 user control for contact interfaces
contracting memory to 2959 d 4976988685 thermal expansion 0
expanding memory to 2961 d 4976988685 state of charge expansion 0
expanding memory to 2963 d 4976988685 cross-sectional force definitions 0
expanding memory to 19325841 d 4976988697 temp index array for node sorting
contracting memory to 2963 d 4996311579 just because?
expanding memory to 15707603 d 5034957367 arbitrary element numbering input
contracting memory to 2964 d 6782829999 process element material data
expanding memory to 4971 d 6782829997 load curve data
contracting memory to 3393 d 6782829997 user_define_loading_set
expanding memory to 3597 d 6782829997 regularize time history data
contracting memory to 3397 d 6782829997 *DEFINE_ELEMENT_DEATH
*** Warning 21374 (STR+1374)
rigidwall ID 2 vectors n and l are not orthogonal
expanding memory to 3602 d 7202044413 contact interfaces
expanding memory to 38650358 d 7202044413 implicit contact 1
expanding memory to 164287480 d 7202044413 implicit contact 2
contracting memory to 4602 d 7340987179 contact segment data 1
expanding memory to 183610356 d 7443422881 contact segment data 3
contracting memory to 3602 d 7832516684 contact definition
expanding memory to 3620 d 7832516685 rigid body
expanding memory to 109752426 d 7876416865 contact friction
expanding memory to 175601730 d 7876416865 joints
expanding memory to 175601830 d 7964216497 rigid bodies for disp. termination
expanding memory to 175601884 d 7964216497 save d3plot control data
expanding memory to 175601886 d 8041508060 mat add cohesive 0
expanding memory to 175601888 d 8041508060 sensor_control for curve
expanding memory to 175601890 d 8041508060 flexible body 2
convergence of normal check obtained in 139 iterations
region 1 has 7317744 segments.
number of independent regions where normal vectors
are checked and if necessary reset = 1
number of renumbered segments = 0
*** Warning 30128 (INI+128)
Massless nodes
The following massless nodes were found
17902 17923 17924 17925 17926 17927
17928 17929 17930 17931 17932 17933
17934 17935 17936 17937 17938 17939
17940 173221 173222
*** Warning 30131 (INI+131)
total number of massless nodes = 21
slave surface of interface = 1
type = 4
surface timestep = 3.267E-08
controlling slave node ID = 19496138
part ID of slave node = 2
current minimum time step = 3.267E-08
The LS-DYNA time step size should not exceed 3.267E-08
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
S t o r a g e a l l o c a t i o n
Memory required to begin solution : 1209M
Additional dynamically allocated memory: 8110M
Total: 9318M
各位老师,最后一行是“Initialization completed”,后面就没有任何信息了,没有提示error也不显示termination,这是什么问题?
