一万多个step,运行出错。。怎么办?
浏览:2091 回答:6
THE RESTART FILE SIZE EXCEEDS THE 16 GB LIMIT. IF THIS ANALYSIS HAS MANY STEPS WITH A LARGE NUMBER OF LOADS OR BOUNDARY CONDITIONS, CONSIDER SPLITTING THE STEPS AMONG SEVERAL ANALYSES AND USING THE RESTART FEATURE TO CONTINUE FROM ONE ANALYSIS TO THE NEXT. AN ALTERNATIVE WORKAROUND IS TO TURN OFF WRITING THE RESTART FILE.
复合材料力学-君莫
