高铁轮-轨-路基abaqus建模
浏览:3175 回答:1
The deformable element nodes contained in node set ErrNodeRotNodeNoRotInert-Step1 have no rotary inertia associated with them and some rotational degrees of freedom at the nodes are not constrained. Either rotary inertia must be defined or all of the rotational degrees of freedom must be constrained. See the status file for further details.
he deformable element nodes contained in node set ErrNodeSpaNodeNoMass-Step1 have no mass associated with them and some translational degrees of freedom at the  nodes are not constrained. Either mass must be definedor all of the translational degrees of freedom must be constrained. See the status file for further details.
技术工
@土木工程师千总 @袁_西建大 @林ads
2016年12月9日
已采纳 评论 点赞
