ABAQUS:模型计算前数据检查出现下面的报错内容?
浏览:6002 回答:7
The deformable element nodes contained in node set ErrNodeRotNodeNoRotInert-Step1 have no rotary inertia associated with them and some rotational degrees of freedom at the nodes are not constrained. Either rotary inertia must be defined or all of the rotational degrees of freedom must be constrained. See the status file for further details.
对于这种错误,一般从哪些方面修改呢,求助大神啊,三天了还没解决
你好!请问这个问题怎么解决的?
