这是我计算前的错误日志,求大神指教
浏览:2664 回答:3
*** ERROR ***                           CP =     109.653   TIME= 18:43:42
 There is not enough memory for the Sparse Matrix solver to proceed.
 Please increase the virtual memory on your system and/or increase the
 work space memory and rerun ANSYS.  Alternatively, forcing the use of
 the minimum out-of-core memory mode (BCSOPTION,,MINIMUM) may allow a
 solution to be achieved without increasing the system memory or
 decreasing the problem size.  The memory currently allocated by ANSYS
 = 320 MB.  The memory allocation attempted = 473 MB.  The largest
 block of ANSYS memory available for the Sparse Matrix solver = 12 MB.
 *** WARNING ***                         CP =     111.073   TIME= 18:47:32
 An increment of 15 is not allowed for the range of 2 TO 1.  The VSEL
 command is ignored.
 *** WARNING ***                         CP =     111.151   TIME= 18:47:32
 EMODIF is not a recognized SOLUTION command, abbreviation, or macro.
  This command will be ignored.
 *** WARNING ***                         CP =     111.229   TIME= 18:47:32
 An increment of 9 is not allowed for the range of 6 TO 3.  The VSEL
 command is ignored.
 *** WARNING ***                         CP =     111.354   TIME= 18:47:32
 *** WARNING ***                         CP =     111.463   TIME= 18:47:32
 An increment of 13 is not allowed for the range of 8 TO 4.  The VSEL
 command is ignored.
 *** WARNING ***                         CP =     111.556   TIME= 18:47:32
 *** WARNING ***                         CP =     111.619   TIME= 18:47:32
 An increment of 21 is not allowed for the range of 10 TO 5.  The VSEL
 command is ignored.
 *** WARNING ***                         CP =     111.712   TIME= 18:47:32
 *** WARNING ***                         CP =     111.822   TIME= 18:47:32
 *** WARNING ***                         CP =     111.946   TIME= 18:47:32
 SOLU is not a recognized BEGIN command, abbreviation, or macro.  This
 *** WARNING ***                         CP =     112.024   TIME= 18:47:32
 ANTYPE is not a recognized BEGIN command, abbreviation, or macro.
 *** WARNING ***                         CP =     112.040   TIME= 18:47:33
 NROPT is not a recognized BEGIN command, abbreviation, or macro.  This
 *** WARNING ***                         CP =     112.071   TIME= 18:47:33
 RESCONTR is not a recognized BEGIN command, abbreviation, or macro.
 *** WARNING ***                         CP =     112.102   TIME= 18:47:33
 OUTRES is not a recognized BEGIN command, abbreviation, or macro.
我是圆周率
明显的是内存不足!
2016年11月7日
智创仿真
第一句就直接告诉你了,内存不足。要么简化模型,减小单元规模,要么换电脑
2016年11月7日
海阔天空5
电脑不行啊 换个牛逼的吧
2016年10月31日
