ABAQUS模型检查问题
浏览:3821 回答:5
8 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
1、请问上面是什么意思??
2、如何查看单元集"WarnElemDistorted"
周游
