ABAQUS模拟? 30
浏览:3150 回答:1
采用ABAQUS做弹塑性膜材的找准静态动力分析,出现如下错误,怎么办 Error in job model33001000suxin: The elements contained in element set ErrElemExcessDistortion-Step2 have distorted excessively. Error in job model33001000suxin: There is only one excessively distorted element Error in job model33001000suxin: The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file. Error in job model33001000suxin: The elements contained in element set ErrElemExcessDistortion-Step2 have distorted excessively.
郑钧 Adam
