s-ale模拟爆炸计算无法进行?
浏览:4564 回答:1
模拟辛春亮老师第二版书中7.1例子,用sale方法模拟炸药炸钢板,用ls-run计算。几个小时进度一直在0%。
这是lsrun.out文件
 License option : check ansys licenses only
 *            ANSYS 2022 R2          LEGAL NOTICES             *
 * Copyright 1971-2022 ANSYS, Inc.  All rights reserved.       *
 * Unauthorized use, distribution or duplication is            *
 * prohibited.                                                 *
 * Ansys is a registered trademark of ANSYS, Inc. or its       *
 * subsidiaries in the United States or other countries.       *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal      *
 * Notice.                                                     *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
 * The software products and documentation are furnished by    *
 * ANSYS, Inc. or its subsidiaries under a software license    *
 * agreement that contains provisions concerning               *
 * non-disclosure, copying, length and nature of use,          *
 * compliance with exporting laws, warranties, disclaimers,    *
 * limitations of liability, and remedies, and other           *
 * provisions.  The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance  *
 * with the terms and conditions of that software license      *
 * agreement.                                                  *
 * ANSYS, Inc. is a UL registered                              *
 * ISO 9001:2015 company.                                      *
 * This product is subject to U.S. laws governing export and   *
 * re-export.                                                  *
 * For U.S. Government users, except as specifically granted   *
 * by the ANSYS, Inc. software license agreement, the use,     *
 * duplication, or disclosure by the United States Government  *
 * is subject to restrictions stated in the ANSYS, Inc.        *
 * software license agreement and FAR 12.212 (for non-DOD      *
 * licenses).                                                  *
      Date: 10/17/2023      Time: 19:42:38
      ___________________________________________________
     |  LS-DYNA, A Program for Nonlinear Dynamic         |
     |  Analysis of Structures in Three Dimensions       |
     |  Date    : 05/10/2022    Time: 17:10:39           |
     |  Version : smp s R13                              |
     |  Revision: R13.1.0-3-g4cd30680f9                  |
     |  Features enabled in this version:                |
     |    Shared Memory Parallel                         |
     |    FFTW (multi-dimensional FFTW Library)          |
     |    Interactive Graphics                           |
     |    ANSYSLIC enabled                               |
     |    MADYMO indirect coupling (7.2 or higher)       |
     |  Licensed to:                                     |
     |  Platform   : WINDOWS X64 (SSE2)                  |
     |  OS Level   : Windows 8/10 & Srv 2016/2019 uum    |
     |  Compiler   : Intel Fortran XE 2019 MSVC++ 2019   |
     |  Hostname   : DESKTOP-28V6PDK                     |
     |  Precision  : Single precision (I4R4)             |
     |  Unauthorized use infringes Ansys Inc. copyrights |
     |___________________________________________________|
[license/info] Successfully checked out 1 of "dyna".
[license/info] --> Checkout ID: DESKTOP-28V6PDK-PC-85800-000002(days left: 4458)
[license/info] Successfully checked out 23 of "FEAT_DYSMP".
[license/info] --> Checkout ID: DESKTOP-28V6PDK-PC-85800-000009(days left: 4458)
[license/info] Successfully started "ANSYS_LSDYNA".
 Executing with ANSYS license
 Command line options: i=C:\dyna\sale——test\input.k
                       ncpu=24
                       memory=20m
 Input file: C:\dyna\sale——test\input.k
 The native file format       : 32-bit small endian
 Memory size from command line:    20000000
 on UNIX computers note the following change:
 ctrl-c interrupts ls-dyna and prompts for a sense  switch.
 type the desired sense switch: sw1., sw2., etc. to continue
 the execution.  ls-dyna will respond as explained in the users manual
    type                      response
   quit    ls-dyna terminates.
   stop    ls-dyna terminates.
   sw1.    a restart file is written and ls-dyna terminates.
   sw2.    ls-dyna responds with time and cycle numbers.
   sw3.    a restart file is written and ls-dyna continues calculations.
   sw4.    a plot state is written and ls-dyna continues calculations.
   swa.    ls-dyna flushes all output i/o buffers.
   swb.    a dynain is written and ls-dyna continues calculations.
   swc.    a restart and dynain are written and ls-dyna continues calculations.
   swd.    a restart and dynain are written and ls-dyna terminates.
   swe.    stop dynamic relaxation just as though convergence
   endtime=time change the termination time
   lpri    toggle implicit lin. alg. solver output on/off.
   nlpr    toggle implicit nonlinear solver output on/off.
   iter    toggle implicit output to d3iter database on/off.
   prof    output timing data to messag and continue.
   conv    force implicit nonlinear convergence for current time step.
   ttrm    terminate implicit time step, reduce time step, retry time step.
   rtrm    terminate implicit at end of current time step.
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LST nor the authors assume any responsibility for  *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. Users must verify their own     *
 * results.                                                   *
 * LST endeavors to make the LS-DYNA code as complete,        *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LST through your site focus.                *
 * Copyright (C) 1990-2022                                    *
 * by Ansys, Inc.                                             *
 * All rights reserved                                        *
 Beginning of keyword reader                                   10/17/23 19:42:40
 Memory required to process keyword     :     357980
 Additional dynamic memory required     :     247340
 *** Warning 30547 (INI+547)
     S-ALE has the 2th multi-material of PART ID: 2
     has a cutoff pressure equal to 0. This might lead to
     nonphysical behavior, pc=-1e+16 is assigned instead.
 S-ALE init volume fraction geometry 1
 S-ALE init volume fraction geometry 2 start                   10/17/23 19:42:40
 S-ALE init volume fraction geometry 2 end                     10/17/23 19:42:40
 input of data is completed
 *** Warning 30064 (INI+64)
     material 140 is not included for silent boundaries
 initial kinetic energy = 0.00000000E+00
 *** Warning 30131 (INI+131)
     total number of massless nodes = 4
 Memory required to begin solution      :     358K
 Additional dynamically allocated memory:    4250K
                                   Total:    4608K
 initialization completed
       1 t 0.0000E+00 dt 4.79E+00 flush i/o buffers            10/17/23 19:42:40
       1 t 0.0000E+00 dt 4.79E+00 write d3plot file            10/17/23 19:42:40
 cpu time per zone cycle............         0 nanoseconds
 average cpu time per zone cycle....         0 nanoseconds
 average clock time per zone cycle..       588 nanoseconds
 estimated total cpu time          =         1 sec (       0 hrs  0 mins)
 estimated cpu time to complete    =         0 sec (       0 hrs  0 mins)
 estimated total clock time        =         6 sec (       0 hrs  0 mins)
 estimated clock time to complete  =         5 sec (       0 hrs  0 mins)
 termination time                  = 3.000E+03
      26 t 9.6285E+01 dt 4.62E+00 write d3plot file            10/17/23 19:42:40
      48 t 1.9830E+02 dt 4.94E+00 write d3plot file            10/17/23 19:42:40
      66 t 2.9594E+02 dt 5.76E+00 write d3plot file            10/17/23 19:42:40
      83 t 3.9861E+02 dt 6.18E+00 write d3plot file            10/17/23 19:42:40
      99 t 4.9860E+02 dt 6.39E+00 write d3plot file            10/17/23 19:42:40
     114 t 5.9746E+02 dt 6.87E+00 write d3plot file            10/17/23 19:42:40
     128 t 6.9612E+02 dt 7.10E+00 write d3plot file            10/17/23 19:42:40
     142 t 7.9558E+02 dt 7.10E+00 write d3plot file            10/17/23 19:42:40
     156 t 8.9504E+02 dt 7.10E+00 write d3plot file            10/17/23 19:42:40
     170 t 9.9450E+02 dt 7.10E+00 write d3plot file            10/17/23 19:42:40
     184 t 1.0940E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     198 t 1.1934E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     213 t 1.3000E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     227 t 1.3994E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     241 t 1.4989E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     255 t 1.5984E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     269 t 1.6978E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     283 t 1.7973E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     297 t 1.8967E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     311 t 1.9962E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     325 t 2.0957E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     339 t 2.1951E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     353 t 2.2946E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     367 t 2.3940E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     381 t 2.4935E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     395 t 2.5930E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     410 t 2.6995E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     424 t 2.7990E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     438 t 2.8984E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
     452 t 2.9979E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
 *** termination time reached ***
     452 t 3.0050E+03 dt 7.10E+00 write d3dump01 file          10/17/23 19:42:41
     452 t 3.0050E+03 dt 7.10E+00 write d3plot file            10/17/23 19:42:41
 N o r m a l    t e r m i n a t i o n                          10/17/23 19:42:41
 Memory required to complete solution   :     358K
                                   Total:    4608K
 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Keyword Processing ... 0.0000E+00    0.00     1.5000E-02    0.48
    KW Reading ......... 0.0000E+00    0.00     3.0000E-03    0.10
    KW Writing ......... 0.0000E+00    0.00     5.0000E-03    0.16
  Initialization ....... 1.0000E+00   33.33     1.7710E+00   56.20
    Init Proc Phase 1 .. 0.0000E+00    0.00     2.4500E-01    7.78
    Init Proc Phase 2 .. 0.0000E+00    0.00     6.7000E-02    2.13
  Element processing ... 0.0000E+00    0.00     2.0300E-01    6.44
    Solids ............. 0.0000E+00    0.00     1.3200E-01    4.19
    E Other ............ 0.0000E+00    0.00     6.1000E-02    1.94
  Binary databases ..... 0.0000E+00    0.00     4.6000E-02    1.46
  ASCII database ....... 0.0000E+00    0.00     2.6000E-02    0.83
  Contact algorithm .... 0.0000E+00    0.00     3.0000E-03    0.10
  ALE FSI Algorithm .... 0.0000E+00    0.00     1.5800E-01    5.01
    FSI ID         1 ... 0.0000E+00    0.00     1.5800E-01    5.01
  S-ALE Advection ...... 2.0000E+00   66.67     8.1300E-01   25.80
    Mesh Update ........ 0.0000E+00    0.00     1.4900E-01    4.73
    Preparation ........ 0.0000E+00    0.00     1.9000E-02    0.60
    Flux Calculation ... 2.0000E+00   66.67     5.4300E-01   17.23
    Post-processing .... 0.0000E+00    0.00     1.0200E-01    3.24
  Time step size ....... 0.0000E+00    0.00     2.0000E-03    0.06
  Others ............... 0.0000E+00    0.00     1.0000E-03    0.03
  Misc. 1 .............. 0.0000E+00    0.00     1.0000E-02    0.32
    Force to Accel ..... 0.0000E+00    0.00     4.0000E-03    0.13
    Update RB nodes .... 0.0000E+00    0.00     2.0000E-03    0.06
  Misc. 2 .............. 0.0000E+00    0.00     3.5000E-02    1.11
  Misc. 3 .............. 0.0000E+00    0.00     1.1000E-02    0.35
  Misc. 4 .............. 0.0000E+00    0.00     5.7000E-02    1.81
    Timestep Init ...... 0.0000E+00    0.00     1.4000E-02    0.44
    Apply Loads ........ 0.0000E+00    0.00     4.3000E-02    1.36
  T o t a l s            3.0000E+00  100.00     3.1510E+00  100.00
 Problem time       =    3.0050E+03
 Problem cycle      =       452
 Total CPU time     =         3 seconds (   0 hours  0 minutes  3 seconds)
 CPU time per zone cycle  =        502.816 nanoseconds
 Clock time per zone cycle=        343.172 nanoseconds
 Number of CPU's   24
 NLQ used/max     136/  136
 Start time   10/17/2023 19:42:40
 End time     10/17/2023 19:42:41
 Elapsed time       1 second  for     452 cycles using 24 SMP threads
             (      0 hour   0 minute   1 second )
