LS-DYNA求解器,出现时间步问题?
浏览:3143 回答:1
各位大佬,LS-DYNA求解器的CESE模块,出现这个问题The LS-DYNA time step size should not exceed 1.026E-06 to avoid contact instabilities. If the step size is bigger then scale the penalty of the offending surface.也没报错就卡住不动了。
我的时间步设置为5e-7。造成这个问题的原因都有哪些?
   CE/SE - State Variables
     DOF ID Variable
          1 Density
          2 X-Momentum
          3 Y-Momentum
          4 Z-Momentum
          5 Total Energy
          & 0 Species Fractions
 input of data is completed
 initial kinetic energy = 0.00000000E+00
 *** Warning 30131 (INI+131)
     total number of massless nodes = 98
 total nodal rigid body mass= 1.0928648E-04
 The LS-DYNA time step size should not exceed     1.025E-06
用户_43907
求,我也遇到一样的问题了
2024年10月17日
