LS-Dyna中如何查询指定节点号的节点?
浏览:4285 回答:5
由message中找到了出错的几个节点号,想找到它们的位置,在LS-PrePost中能实现吗?
*** Warning 30128 (INI+128)
Massless nodes
The following massless nodes were found
75202 75203 75204 75205 75206 75207
Massless nodes
75208 75209
*** Warning 30131 (INI+131)
total number of massless nodes = 8
The LS-DYNA time step size should not exceed 8.115E-05
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
lspp中有find功能,点选node 输入节点编号,就可以了,GLuck
