workbench ls-dyna预应力求解问题? 10
浏览:3453
通过static structure给ls-dyna模块加预应力分析,但是在mesh设置中出现了两个分析冲突的设置,具体是,在static structure分析时,要求将rigid body behavior设置为dimensionally reduced,设置之后此部分就可以顺利求解,但是到ls-dyna求解时,提示错误:The mesh has a rigid body behavior set to Dimensionally Reduced. This behavior is invalid for LS-DYNA,请问各位大神怎么解决这个问题
