Hypermesh #error 3840怎么处理? 100
浏览:2339 回答:1
 A fatal error has been detected during input processing:
  *** ERROR # 3840 ***
  The eigenvalue solution for solving CMS modes has failed to obtain
  the desired modes.
      dimension of eigen problem = 24
        obtained number of modes = 0
  The failure is likely to be caused by misplaced interface nodes or
  ill-conditioned eigen problem.  Please check the model and rerun
  the problem.  If you cannot resolve this error, please send the input
  model to ossupport for debugging.
这个ossupport是什么啊
CAE追梦者
模型方便发过来我看看
2021年1月21日
