求大神帮忙,hypermesh过程中发生错误,能解释下吗?
浏览:3055 回答:3
*** ERROR # 153 ***
 Exactly zero pivoting encountered during Numerical Factorization;
 the model may have rigid body mode.
  Solver error no. =   -503
        spc set id = 6
             index =      1
 Possible reasons are:
 1) insufficiently constrained model,
 2) having rigid body mechanisms within the model,
 3) extremely ill-conditioned rigid element sets,
 4) extremely thin shells (as used for skinning) that have MID2/MID3,
 5) gap elements with extremely high stiffness (KA, especially KT or MU).
 Check the model and rerun the problem.
 (MECHCHECK may be used to find the rigid body modes.  To do so,
  change the input to be an eigenvalue analysis and add MECHCHECK.)
 (WARNING: results obtained with MECHCHECK cannot be used because
          the model is changed internally.)
 This error was detected in subroutine bcsmtxfct.
 This error occurs in module "lstatdrv".
丰阳
约束不足 有刚体模态
2018年5月5日
TechmanLXS
把out文件贴出来看一下呢,你这个做的是优化分析吗?
2018年1月15日
工程计算与仿真
rigid有问题,看看是否是约束过刚
2018年1月14日
