ANSYS网格划分出错?
浏览:8060 回答:2
1、The mesh generation did not complete due to poor quality elements or incorrect input. Please try meshing with another mesh method or different mesh options.
2、One or more surfaces or surface boundaries might not be oriented correctly.
3、Copying the source mesh to the target face failed because of poor quality. Setting or adjusting size controls might help the sweeper in generating higher quality source and target face meshes.
4、Mass properties (volume, surface area, centroid, moments of inertia) may be inaccurate: 2101772-
请问这四种情况怎么解决5啊,谢谢
The second question:
Right click on the message and click "Show problematic geometry" and see if that points towards problematic faces in your model. Once found, clean it up in CAD or SpaceClaim or DesignModeler and retry.
