ansys mesh在生成体网格的时候出现错误? 20
浏览:5311
1.
The inflation layer generation did not complete. This may be due to poor quality patches in the surface mesh, sharp geometric features, or narrow passages.
2.
Patch-conforming tetrahedral mesh failed because of an edge intersection in boundary or inflation mesh.
3.
A mesh could not be generated using the current meshing options and settings.
海阔天空5
体网格生成时有些特征无法生成网格,你可以检查error的位置。error右击,show problemtic geomory,然后看看是否可以去前处理修改下模型。
2021年3月15日
