电脑内存足够,网格划分不算太多,求解还老是出错
浏览:5288 回答:7
电脑内存原来是8g,后来加装了8g的内存条,网格划分的数量跟加装内存条前差不多,也就15万网格,为什么求解时老是出现下面的问题,上网查了很久,都没查到原因,求大神解救。
问题如下:
*** WARNING ***                         CP =      55.141   TIME= 21:45:50
 The Distributed Sparse Matrix Solver is currently running in the
 out-of-core memory mode.  This memory mode may provide significantly
 worse performance compared to the in-core memory mode, depending on
 the amount of available system memory and I/O speed.  Please monitor
 the solver performance to ensure that the large amount of I/O to the
 solver files does not create a bottleneck for performance.
 *** ERROR ***                           CP =      98.562   TIME= 21:46:41
 An input/output error has occurred while trying to open a file with
 length = 3 GB.  Error code = 112, which translates to: 磁盘空间不足。
 The program is unable to open file file1.DSPtri.  If the suggestions in
 the associated error messages immediately preceding and/or following
 this error message do not help resolve the file issue, please send the
 data leading to this operation to your technical support provider,
 along with the I/O error code of -1 and the system error code of 0,
 for help in determining the possible reasons as to why this file could
 not be opened.
 An input/output error has occurred on the process with MPI Rank ID = 1.
  This error occurs when trying to open a file with length = 4 GB.
 Please check to make sure there is enough free disk space in the
 working directory (E:\zuijin\anli\_ProjectScratch\Scr5288) on machine
 (DESKTOP-J2BGQ1T).
(5)
海阔天空5
另存为别的盘,不要在C盘里,不要有中文路径,试一下!
2019年7月23日
已采纳 评论 1 点赞 1
kouchenguang
我也遇到相同的问题了,请问解决了么?
2023年7月13日
哇泡泡啊泡泡
mechanical计算遇到了相同的问题,求怎么解决的呀
2023年6月19日
数理统计
把路径下东西都删了,重新计算
2022年11月18日
安远歌~
请问您后来找到解决办法了吗,我这边也遇到了类似的问题。非常的奇怪
2022年10月31日
