能不能摆脱大神们帮我看下这个错误怎么改?
浏览:2059 回答:1
买的视频里结尾没有运行。到保存就没了。
自己做的时候老是出现这种错误:
The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
The elements in element set ErrElemZeroALEMass-Step1 have zero or negative mass.
Print-out suppressed for subsequent distorted elements
There are a total of 195 excessively distorted elements.
运行出来大约就是这样的。
材料里面定义失效参数,定义单独的剪切带
