ANSYS热应力分析出现下面提示如何解决?
浏览:2186 回答:1
*** WARNING *** SUPPRESSED MESSAGE CP = 96.580 TIME= 15:36:32
Specified constraints on slave degrees of freedom in a coupled set are
not allowed. The constraint on this degree of freedom has been
removed: coupled set number 2, slave node 1299, UY
你使用了节点耦合,在其中一个耦合集的 从节点 1299 的自由度 Uy 上施加了约束,这是不允许的。
