ABAQUS的vusdfld模拟组织遇到云图显示错误和黑色区域的问题?
浏览:2456 回答:5
在这里附上子程序的内容,麻烦相关人士指正错误:
 subroutine vusdfld(
c Read only -
     *   nblock, nstatev, nfieldv, nprops, ndir, nshr,
     *   jElemUid, kIntPt, kLayer, kSecPt,
     *   stepTime, totalTime, dt, cmname,
     *   coordMp, direct, T, charLength, props,
     *   stateOld,
c Write only -
     *   stateNew, field )
c
      include 'vaba_param.inc'
c
      dimension props(nprops),
     *          jElemUid(nblock), coordMp(nblock, *),
     *          direct(nblock, 3, 3), T(nblock,3,3),
     *          charLength(nblock),
     *          stateOld(nblock, nstatev),
     *          stateNew(nblock, nstatev),
     *          field(nblock, nfieldv)
      character*80 cmname
      parameter( nrData=6 )
      character*3 cData(maxblk*6)
      dimension jData(maxblk*nrData)
      dimension temp(maxblk*6), eqps(maxblk*6)
      jStatus = 1
      call vgetvrm( 'TEMP', temp, jData, cData, jStatus )
      jStatus = 1
      call vgetvrm( 'PEEQ', eqps, jData, cData, jStatus )
      do k = 1, nblock
       if ( stepTime .eq. 0 ) then
      stateOld(k,1) = 0
      stateOld(k,2) = 0
      stateOld(k,3) = 0
      stateOld(k,4) = 0
      stateOld(k,5) = 20
      stateOld(k,6) = 0
       end if
        Te = temp(k)
        stateNew(k,1) = Te
        str = eqps(k)
        stateNew(k,2) =  str
        str1 = stateOld(k,2)
        strra = (str-str1)/dt
        stateNew(k,3) =  strra
          zpara = strra*exp(300/(Te+273))
          stateNew(k,6) =  zpara
 !       end if
           eqc= 0.00158*zpara**0.10662
           eq05=0.018063*zpara**0.08518
           dfull=1.27e6*zpara**(-0.351)
          if (str.ge. eqc) then
              de= (str-eqc)/(eq05-eqc)
              Xdrx=1-exp(-0.693*(de)**1.92)
              if (Xdrx .ge. 0.95) then
              stateNew(k,4) = 1
              stateNew(k,5) = dfull
              else
              stateNew(k,4) =  Xdrx
              stateNew(k,5) = dfull*Xdrx+(1-Xdrx)*20
              endif
          end if
      end do
      return
      end
铁木辛科上单
我也遇到了同样的问题,但是数值结果上看是没问题的
2022年6月5日
..._1141
我遇到了同样的问题
2019年5月9日
评论 3 点赞
