关于VUSDFLD中新旧变量的提取问题?
浏览:2834 回答:6
最近,我再将以前写的一个隐式计算的USDFLS的子程序改写为VUSDFLD,结果遇到的问题
我使用vusdfld在实现单元的删除,在里面计算等效塑性应变的增量的时候,我令一个变量等于stateOld,然后用stateNew减去这个值来实现我的目的,为什么不行?也就是stateOld里面并不是存的上一步的等效塑性应变的结果?
这个问题困扰我很久了,能否有大神助一臂之力的?
附上子程序和inp文件,以及odb的结果
c
c User subroutine VUSDFLD for user-defined fields
c
      subroutine vusdfld(
c Read only -
     *   nblock, nstatev, nfieldv, nprops, ndir, nshr,
     *   jElemUid, kIntPt, kLayer, kSecPt,
     *   stepTime, totalTime, dt, cmname,
     *   coordMp, direct, T, charLength, props,
     *   stateOld,
c Write only -
     *   stateNew, field )
c
      include 'vaba_param.inc'
c
      dimension props(nprops),
     *          jElemUid(nblock), coordMp(nblock, *),
     *          direct(nblock, 3, 3), T(nblock,3,3),
     *          charLength(nblock),
     *          stateOld(nblock, nstatev),
     *          stateNew(nblock, nstatev),
     *          field(nblock, nfieldv)
      character*80 cmname
      parameter( nrData=6 )
      character*3 cData(maxblk*6)
      dimension jData(maxblk*nrData)
      dimension eqps(nblock,maxblk*6),stress(nblock,maxblk*6)
    	real dc,rc,plim,alpha,beta,eqpsOld,damageOld
c
      parameter ( zero = 0.d0 )
C 定义损伤的极限值
      parameter ( one = 1.d0 )
C 通过vgetvrm函数来获取等效塑性应变和应力分量
      jStatus = 1
      call vgetvrm( 'PEEQ', eqps, jData, cData, jStatus )
	  call vgetvrm( 'S', stress, jData, cData, jStatus )
C 循环进行进行求解响应的变量
      do k = 1, nblock
		 damageOld = stateOld(k,10)
c-----------------------------------------------------------------------c
C 主要是计算应力三轴度
C 首相将提取的应力分量赋给状态变量/变量,用来计算mises应力和静水压力
C		 stateNew(k,51) = stress(k,1)
		 stress1 = stress(k,1)
C		 stateNew(k,52) = stress(k,2)
		 stress2 = stress(k,2)
C		 stateNew(k,53) = stress(k,3)
		 stress3 = stress(k,3)
C		 stateNew(k,54) = stress(k,4)
		 stress4 = stress(k,4)
C		 stateNew(k,55) = stress(k,5)
		 stress5 = stress(k,5)
C		 stateNew(k,56) = stress(k,6)
		 stress6 = stress(k,6)
C 计算mises应力和静水压力
		 smises1 = (stress1-stress2)**2+(stress2-stress3)**2+(stress1-stress3)**2
		 smises = (0.5*smises1)**0.5
		 hpress = (stress1+stress2+stress3)/3.0
C 将计算的mises应力和静水压力赋给状态变量
		 stateNew(k,1) = smises
		 stateNew(k,2) = hpress
C 计算应力三轴度,并将其赋给状态变量
		 if(smises.le.stoler) then
			triax=0.d0
		 else
			triax=(1.0*hpress)/smises
		 endif
		 stateNew(k,3) = triax
C 主要是计算断裂应变
c	根据确定的系数和计算的应力三轴度,计算临界断裂应变,并将其赋给状态变量
		 frac_strain = 1.556*exp(-1.5*triax)+0.093
		 stateNew(k,4) = frac_strain
C 主要是计算损伤增量
C 上一步的等效塑性应变stateNew(k,5),该步的等效塑性应变stateNew(k,6),增量stateNew(k,7)
C		 if(stepTime.eq.zero) then
C			stateNew(k,5) = 0.0
C			stateNew(k,6) = 0.0
C		 else
			stateNew(k,5) = stateOld(k,6)
C		 endif
		 stateNew(k,6) = eqps(k,1)
		 stateNew(k,7) = stateNew(k,6)-stateNew(k,5)
C 该步的损伤增量
		 stateNew(k,8) = stateNew(k,7)/stateNew(k,4)
C 初始的损伤量
C			stateNew(k,9) = 0.0
C			stateNew(k,10) = 0.0
C		 else
			stateNew(k,9) = damageOld
C		 endif
C 该步的损伤增量
		 stateNew(k,10) = stateNew(k,9) + stateNew(k,8)
		 stateOld(k,10) = stateNew(k,10)
C 根据损伤量的大小来对网格进行删除
         if(stateNew(k,10).gt.one) then
c Element Deletion
           stateNew(k,11) = zero
         endif
      end do
c
      return
      end
关于VUSDFLD中新旧变量的提取问题?的图1
关于VUSDFLD中新旧变量的提取问题?的图2
蓝牙
      do k = 1, nblock
这句实在不解,为何要做循环
2.stateold用来承上启下,最后你要更显这个值啊,要不你怎么传递给下一个载荷步
2018年5月27日
评论 6 点赞
