abaqus xfem分析时某个单元扩展不了?
浏览:2498 回答:1
The system error in std_findcutshape3d8_xfem -- nodal level set values might not be correct for element 9104 instance part-1-1
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
能提供错误提示中单元的具体位置么?包含在模型里的
