地震时程分析出现如下警告怎么解决? 40
浏览:1941
*** WARNING *** CP = 4077.164 TIME= 10:22:17
A reference moment value times the tolerance is used by the Newton-Raphson method for checking convergence. The calculated reference MOMENT CONVERGENCE VALUE = 5.114045982E-03 is less than a threshold. This threshold defaults to 1.0-2 or is specified as MINREF on the CNVTOL command. Check results carefully.
