abaqus作业检查出现问题,怎么解决?
浏览:3058 回答:7
作业输入文件 "zhengti-1.inp" 已提交分析.
Error in job zhengti-1: The volume of 1 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Job zhengti-1: Analysis Input File Processor aborted due to errors.
Error in job zhengti-1: Analysis Input File Processor exited with an error.
Job zhengti-1 aborted due to errors.
