ABAQUS计算过程报错,如何解决?
浏览:4522 回答:1
Job Job-2: Analysis Input File Processor completed successfully.
Error in job Job-2: Too many attempts made for this increment
Job Job-2: Abaqus/Standard aborted due to errors.
Error in job Job-2: Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
Job Job-2 aborted due to errors.
Output request damaget is not available for the material for element type c3d8
Output request damaget is not available for the material for element type s4
166117 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
The aspect ratio for 130 elements exceeds 100 to 1. The elements have been identified in element set WarnElemAspectRatio.
1 elements are curved/warped. The angle subtended between the average element normal and a nodal normal exceeds 10 degrees. Mesh refinement is recommended. The elements have been identified in element set WarnElemWarped.
There are 116 unconnected regions in the model.
The plasticity/creep/connector friction algorithm did not converge at 800579 points
The plasticity/creep/connector friction algorithm did not converge at 1142412 points
The plasticity/creep/connector friction algorithm did not converge at 1238922 points
The plasticity/creep/connector friction algorithm did not converge at 1270393 points
The plasticity/creep/connector friction algorithm did not converge at 1278392 points
请教大佬如何解决
TechmanLXS
不收敛,去你的msg看下详细信息。
2023年10月27日
