ANSYS接触模拟中出现这种警告问题该怎么解决? 20
浏览:1975 回答:1
 *** WARNING ***                         CP =      42.641   TIME= 15:31:25
 Some target elements on target surface specified by real constant set
 301 belong to symmetric contact (e.g.  21 and 42), some do not.
 *** WARNING ***                         CP =      42.797   TIME= 15:31:25
 Some contact elements on contact surface specified by real constant set
 11 belong to symmetric contact (e.g.  26), some do not.
*** WARNING ***                         CP =     100.078   TIME= 15:31:53
 There are 32 small equation solver pivot terms.
大龙猫🐱
接触面设置到对称面上了,有冲突,警告不影响计算看看,结果正确就行
2018年5月27日
已采纳 评论 点赞
