ABAQUS隐式分析结果文件可以写入.dat文件,那显示分析写入哪个文件呢? 50
浏览:2715 回答:2
请教各位,在有限元模拟中,我想通过Fortran编写子程序,实现非均布的加载,在这个过程中,想让ABAQUS输出dat结果文件,利用Fortran读取dat文件中的变量信息,再来更新加载方式,计算同时进行,dat文件和加载方式都不断更新,如此循环往复。结果在操作过程中发现显示分析不能将结果写入.dat文件,查到好像可以写入.fil文件,但是不知道Fortran能否调用.fil文件,还望大神们指导。
星辰_北极星
具体可以看下帮助文档分析手册:3.7.1 Fortran unit numbers used by Abaqus
CodeUnit NumberDescription
Abaqus/Standard1Internal database
2Solver file
6Printed output (.dat) file (You can write output to this file.)
7Message (.msg) file (You can write output to this file.)
8Results (.fil) file
10Internal database
12Restart (.res) file
19–30Internal databases (scratch files). Unit numbers 21 and 22 are always written to disk.
73Text file containing meshed beam cross-section properties (.bsp)
Abaqus/Explicit6Printed output (.log) .
13Old restart (.res) file, if applicable
15Analysis Preprocessor (.dat or .pre) file
23Communications (.023) file
60Global package (.pac) file
61Global state (.abq) file
62Temporary file
63Global selected results (.sel) file
64Message (.msg) file
65Output database (.odb) file
67Old package (.pac) file, if import from Abaqus/Explicit
68Old state (.abq) file, if import from Abaqus/Explicit
69Internal database; temporary file
If domain-parallel70Local package (.pac.1) file for CPU #1
71Local state (.abq.1) file for CPU #1
73Local selected results (.sel.1) file for CPU #1
80Local package (.pac.2) file for CPU #2
81Local state (.abq.2) file for CPU #2
83Local selected results (.sel.2) file for CPU #2
...Add three files, incrementing units by 10, for each additional CPU
2018年6月3日
已采纳 评论 点赞 1
北方小镇
你好,我也用到这种功能,不知道你现在解决了吗?方便加qq247301740交流吗
2020年6月16日
