遇到错误,求大神解答。我的QQ 1049582278,有偿谢答?
浏览:1673 回答:5
The volume of 387 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
光阴
