abaqus调用子程序问题,大神求助?
浏览:1717
abaqus中由于有接触约束,所以interaction properties中定义mechanical中tangential behavior的friction properties为0.3。以上为摩擦系数定义。提交文件后提示user subroutine voidri is missing,然后我edit 这个job在general中的user suboutine file中导入knee_vfriction.obj,提交文件后提示problem during linking-abaqus/standard user subroutines.this error may be due to a mismatch in the abaqus user suboutine argument.these arguments sometimes change from release to release ,so user subroutines used with a previous release of abaqus may need to be adjusted.请问如何解决???
