ls-dyna中怎么查看梁单元节点的转角? 151
浏览:2852 回答:6
问题描述:一个简支梁(10个梁单元,单元之间的节点附加集中质量)中点受到一个阶跃载荷。想要得到梁单元节点的转角。
在lspp中查看rx-displacement一直为零。然后看手册写查看rx-displacement要用到离散梁单元,然后换了section_beam type6,mat 66。结果每个梁单元就像关节脱臼一样,在梁单元节点处随意甩动,最终消失。
还要谢谢曹老师的帮助。
$# LS-DYNA Keyword file created by LS-PrePost(R) V4.3.11 - 04Jul2017
$# Created on Oct-12-2017 (11:17:04)
*KEYWORD
*TITLE
$#        title
LS-DYNA keyword deck by LS-PrePost
*CONTROL_TERMINATION
$#  endtim    endcyc     dtmin    endeng    endmas
      60.0         0       0.0       0.0       0.0
*DATABASE_DISBOUT
$#      dt    binary      lcur     ioopt
       0.0         0         0         1
*DATABASE_DEFORC
       0.0         0         0         1
*DATABASE_ELOUT
$#      dt    binary      lcur     ioopt   option1   option2   option3   option4
       0.0         0         0         1         0         0         0         0
*DATABASE_GLSTAT
       0.0         0         0         1
*DATABASE_GLSTAT_MASS_PROPERTIES
       0.0         0         0         1
*DATABASE_MATSUM
       0.0         0         0         1
*DATABASE_NODOUT
       0.0         0         0         1       0.0         0
*DATABASE_BINARY_D3PLOT
$#      dt      lcdt      beam     npltc    psetid
       0.1         0         0         0         0
$#   ioopt
         0
*DATABASE_HISTORY_BEAM
$#     id1       id2       id3       id4       id5       id6       id7       id8
        16         0         0         0         0         0         0         0
*DATABASE_HISTORY_NODE
        15         0         0         0         0         0         0         0
*BOUNDARY_SPC_NODE
$HMNAME LOADCOLS       1SPC
$HWCOLOR LOADCOLS       1       8
$#     nid       cid      dofx      dofy      dofz     dofrx     dofry     dofrz
        12         0         1         1         1         1         0         0
$HMNAME LOADCOLS       3SPC_R
$HWCOLOR LOADCOLS       3      24
        22         0         0         1         1         0         0         0
*LOAD_NODE_POINT
$#     nid       dof      lcid        sf       cid        m1        m2        m3
        17         2         1       1.0         0         0         0         0
*PART
$#        title
auto created
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         2         1         3         0         0         0         0         0
*SECTION_BEAM
$HMNAME PROPS       1BAR_PROPERTY
$#   secid    elform      shrf   qr/irid       cst     scoor       nsm
         1         6       1.0         2         1       3.0       0.0
$#     vol      iner       cid        ca    offset     rrcon     srcon     trcon
      50.0       0.0         0       0.0       0.0       0.0       0.0       0.0
*MAT_LINEAR_ELASTIC_DISCRETE_BEAM
$#     mid        ro       tkr       tks       tkt       rkr       rks       rkt
         37.90000E-9     10000     10000     10000     100.0     100.0     100.0
$#     tdr       tds       tdt       rdr       rds       rdt
       0.0       0.0       0.0       0.0       0.0       0.0
$#     for       fos       fot       mor       mos       mot
*MAT_ELASTIC
$HMNAME MATS       1steel
$#     mid        ro         e        pr        da        db  not used
         17.90000E-9  210000.0       0.3       0.0       0.0         0
*DEFINE_CURVE
$#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
         1         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
               0.001               100.0
                10.0               100.0
              10.001                 0.0
                12.0                 0.0
*ELEMENT_BEAM
$#   eid     pid      n1      n2      n3     rt1     rr1     rt2     rr2   local
      12       2      12      13      23       0       0       0       0       2
      13       2      13      14      24       0       0       0       0       2
      14       2      14      15      25       0       0       0       0       2
      15       2      15      16      26       0       0       0       0       2
      16       2      16      17      27       0       0       0       0       2
      17       2      17      18      28       0       0       0       0       2
      18       2      18      19      29       0       0       0       0       2
      19       2      19      20      30       0       0       0       0       2
      20       2      20      21      31       0       0       0       0       2
      21       2      21      22      32       0       0       0       0       2
*ELEMENT_MASS
$HMNAME COMPS       1auto1
$HWCOLOR COMPS       1      11
$#   eid     nid            mass     pid
       1       1            0.01       1
       2       2             1.0       1
       3      11             1.0       1
       4      10             1.0       1
       5       9             1.0       1
       6       8             1.0       1
       7       7             1.0       1
       8       6             1.0       1
       9       5             1.0       1
      10       4             1.0       1
      11       3             1.0       1
*NODE
$#   nid               x               y               z      tc      rc
       1          1000.0             0.0             0.0       0       0
       2             0.0             0.0             0.0       0       0
       3           100.0             0.0             0.0       0       0
       4           200.0             0.0             0.0       0       0
       5           300.0             0.0             0.0       0       0
       6           400.0             0.0             0.0       0       0
       7           500.0             0.0             0.0       0       0
       8           600.0             0.0             0.0       0       0
       9           700.0             0.0             0.0       0       0
      10           800.0             0.0             0.0       0       0
      11           900.0             0.0             0.0       0       0
      12             0.0             0.0             0.0       0       0
      13           100.0             0.0             0.0       0       0
      14           200.0             0.0             0.0       0       0
      15           300.0             0.0             0.0       0       0
      16           400.0             0.0             0.0       0       0
      17           500.0             0.0             0.0       0       0
      18           600.0             0.0             0.0       0       0
      19           700.0             0.0             0.0       0       0
      20           800.0             0.0             0.0       0       0
      21           900.0             0.0             0.0       0       0
      22          1000.0             0.0             0.0       0       0
      23             0.0            10.0             0.0       0       0
      24           100.0            10.0             0.0       0       0
      25           200.0            10.0             0.0       0       0
      26           300.0            10.0             0.0       0       0
      27           400.0            10.0             0.0       0       0
      28           500.0            10.0             0.0       0       0
      29           600.0            10.0             0.0       0       0
      30           700.0            10.0             0.0       0       0
      31           800.0            10.0             0.0       0       0
      32           900.0            10.0             0.0       0       0
*END
ls-dyna中怎么查看梁单元节点的转角?的图1beam.k
蓝牙
换成type 6 就不是传统的梁啦 那就不要这种方法,你先试下用Database_NODOUT! 如果不行,我再告诉你最后一种方法!
2017年10月12日
已采纳 评论 4 点赞
七十七--
@蓝牙 谢谢曹老师,还请再帮忙看一下。
2017年10月12日
