刚体圆柱带动外部圆环自转问题,为何外部圆环无法转动?
浏览:1948 回答:14
建立的模型如图,内部为刚体,施加自转角速度,带动外部物体绕中心轴转动,但是无法计算,一直出现变形过大,查看部分计算结果是外部圆环被约束住了,无法转动。请各位大神老师指导一下是什么原因?
/REPLOT,RESIZE
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_MULTI,0
KEYW,LSDYNA,1
KEYW,PR_DYNA,1
/GO
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM,  Structural with LS-DYNA Explicit
/PREP7
ET,1,SOLID164
ET,2,SOLID164
MP,DENS,1,7.8
MP,EX,1,2.1
MP,NUXY,1,0.3
EDMP,RIGI,2,0,0
MP,DENS,2,7.8
MP,EX,2,2.1
MP,NUXY,2,0.3
CYLIND,10,8,0,15,0,360,
CYLIND,8,0,0,15,0,360,
KWPAVE,       9
wpro,,90.000000,
FLST,2,2,6,ORDE,2
FITEM,2,1
FITEM,2,-2
VSBW,P51X
CSYS,0
WPAVE,0,0,0
CSYS,0
wpro,,,90.000000
FLST,2,4,6,ORDE,2
FITEM,2,3
FITEM,2,-6
VSBW,P51X
FLST,2,8,6,ORDE,4
FITEM,2,1
FITEM,2,-2
FITEM,2,7
FITEM,2,-12
VGLUE,P51X
FLST,5,8,4,ORDE,4
FITEM,5,1
FITEM,5,-4
FITEM,5,9
FITEM,5,-12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,16,4,ORDE,6
FITEM,5,21
FITEM,5,-28
FITEM,5,37
FITEM,5,-40
FITEM,5,43
FITEM,5,-46
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,8, , , , ,1
FLST,5,8,4,ORDE,4
FITEM,5,31
FITEM,5,-32
FITEM,5,56
FITEM,5,-61
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,2, , , , ,1
FLST,5,9,4,ORDE,9
FITEM,5,17
FITEM,5,-18
FITEM,5,29
FITEM,5,-30
FITEM,5,41
FITEM,5,-42
FITEM,5,47
FITEM,5,49
FITEM,5,53
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,2,8,6,ORDE,2
FITEM,2,1
FITEM,2,-8
VGLUE,P51X
TYPE,   1
MAT,       1
REAL,
ESYS,       0
SECNUM,
MSHAPE,0,3D
MSHKEY,1
FLST,5,4,6,ORDE,2
FITEM,5,3
FITEM,5,-6
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE,   2
MAT,       2
REAL,
ESYS,       0
SECNUM,
FLST,5,4,6,ORDE,4
FITEM,5,1
FITEM,5,-2
FITEM,5,7
FITEM,5,-8
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
EDPART,CREATE
PARTSEL,'PLOT'
*DIM,TIME,ARRAY,2,1,1, , ,
*SET,TIME(2,1,1) , 10
*DIM,DISP,ARRAY,2,1,1, , ,
*SET,DISP(2,1,1) , 10
*SET,DISP(1,1,1) , 10
EDLOAD,ADD,RBOZ,0,       2,TIME,DISP, 0, , , , ,
FINISH
/SOL
TIME,10,
EDRST,30,
EDHTIME,50,
EDDUMP,1,
EDOPT,ADD,blank,LSDYNA
EDOUT,GLSTAT
EDENERGY,1,1,1,1
(8)
我给你幸福
您好,能加下楼主的qq吗 我也是做空心圆柱的仿真,不会施加约束 想请假你一下
2017年5月22日
独孤神宇
EDMP,RIGI,2,0,0 改为 EDMP,RIGI,2,7,4 , 我也做这个刚体带动柔体的 仿真? 可以一起交流一下 QQ 523074926
2017年4月26日
邹正刚
  试了一下你的命令流,发现以下问题:
  1  材料 2 虽然定义为 rigid,但是没有给出具体约束了哪些位移;
  2  两种材料的性能数据太离谱。由于弹性模量太小 (数值为 21,不知是什么单位?什么材料?),稍一受力就会产生很大的变形,导致单元高度扭曲,造成负体积,而不收敛。
  3  没有施加任何约束,结构产生刚体运动,计算时软件会出现警告信息。
  最终以大量单元负体积而停止计算。
  对以上问题进行修改:对材料 2 设置约束除 ROTz 外的其它自由度;两种材料的性能数据使用钢的数据:弹性模量 2.1E11;质量密度 7800。在中心线两端添加约束,使其只能有 ROTz 的转动。
  终止时间设置为 100 s,计算到 90 s 之后才出现负体积,而终止计算。
  一些结果如下:
out_is_fixed.txt
 其中,三个图片分别是不同时间的周向位移,可以看到 10s 时外层也是在转动的;90s 时,外层已经开始发生单元高度扭曲的现象。
  txt 文件为修改后的命令流。
2017年4月24日
奈文摩尔
既然提示了这个错误,你得看看你是否有约束外面节点自由度的操作
2017年4月21日
邹正刚
1 材料 2 定义为 rigid,但是没有约束任何自由度。 2 整个模型也没有施加任何约束;只有一个转动载荷 ROTz。 3 计算时出现 160 个错误,主要是负体积问题,因此计算被终止,没有结果。
2017年4月18日
已采纳 评论 3 点赞
邹正刚
你的计算中出现了大量负体积的错误,能有计算结果吗?
2017年4月18日
邹正刚
命令流中: *SET,DISP(2,1,1) , 10 *SET,DISP(1,1,1) , 10 是否有误?改为: *SET,DISP(2,1,1) , 10 *SET,DISP(1,1,1) , 0 试试。
2017年4月17日
技术工
@dyna_focus @ 蓝牙@奈文摩尔
2017年4月17日
