新人ANSYS求解的时候没反应,大神帮忙分析一下,命令流已经上传? 20
浏览:3757 回答:7
/prep7
k,1
k,2,40,-27.5
k,3,-40,-27.5
k,4,50,-55
k,5,-50,-55
k,6,50,-82.5
k,7,-50,-82.5
k,8,-50,-110
k,11,-35,-137.5
k,12,40,-137.5
k,14,35,-165
k,17,-35,-220
k,18,35,-220
k,19,-40,-247.5
k,20,40,-247.5
k,21,0,-275
k,13,-20,-165
k,10,50,-110
k,15,-25,-192.5
k,16,35,-192.5
k,22,0,0,30
k,23,25,-27.5,
k,24,-25,-27.5,
k,25,-25,-82.5,
k,26,25,-82.5,
k,27,-17.5,-165
k,27,-15,-165
k,28,15,-165
k,29,-15,-247.5
k,30,15,-247.5
k,31,15,-247.5,20
k,26,25,-82.5,15
k,32,25,-82.5,15
k,26,25,-82.5
LSTR,       1,      22
LSTR,      26,      32
LSTR,      30,      31
LARC,       2,       3,       1
LSTR,       2,       4
LSTR,       4,       6
LSTR,       6,      10
LSTR,      10,      12
LSTR,      12,      14
LSTR,      14,      16
LSTR,      16,      18
LSTR,      18,      20
LSTR,      20,      21
LSTR,      21,      19
LSTR,      19,      17
LSTR,      17,      15
LSTR,      15,      13
LSTR,      13,      11
LSTR,      11,       8
LSTR,       8,       7
LSTR,       7,       5
LSTR,       5,       3
LSTR,      23,      24
LSTR,      24,      25
LSTR,      25,      26
LSTR,      26,      23
LSTR,      28,      27
LSTR,      27,      29
LSTR,      29,      30
LSTR,      30,      28
SAVE
LFILLT,5,6,30, ,
LFILLT,7,8,30, ,
LFILLT,12,13,30, ,
LFILLT,13,14,30, ,
LFILLT,14,15,30, ,
LFILLT,17,18,30, ,
LFILLT,16,17,30, ,
LFILLT,19,20,30, ,
LFILLT,21,22,30, ,
LFILLT,23,26,10, ,
LFILLT,23,24,10, ,
LFILLT,26,25,10, ,
LFILLT,25,24,10, ,
LFILLT,27,30,10, ,
LFILLT,27,28,10, ,
LFILLT,30,29,10, ,
LFILLT,29,28,10, ,
SAVE
FLST,2,28,4
FITEM,2,4
FITEM,2,5
FITEM,2,31
FITEM,2,6
FITEM,2,7
FITEM,2,32
FITEM,2,8
FITEM,2,9
FITEM,2,10
FITEM,2,11
FITEM,2,12
FITEM,2,33
FITEM,2,13
FITEM,2,34
FITEM,2,35
FITEM,2,14
FITEM,2,15
FITEM,2,16
FITEM,2,37
FITEM,2,17
FITEM,2,36
FITEM,2,18
FITEM,2,19
FITEM,2,38
FITEM,2,20
FITEM,2,21
FITEM,2,39
FITEM,2,22
AL,P51X
LPLOT
FLST,2,8,4
FITEM,2,40
FITEM,2,23
FITEM,2,41
FITEM,2,24
FITEM,2,26
FITEM,2,25
FITEM,2,43
FITEM,2,42
AL,P51X
FLST,2,8,4
FITEM,2,44
FITEM,2,27
FITEM,2,45
FITEM,2,28
FITEM,2,30
FITEM,2,29
FITEM,2,47
FITEM,2,46
AL,P51X
SAVE
VDRAG,       1, , , , , ,       1
alist, all
APLOT
LPLOT
VDRAG,       2, , , , , ,       2
VDRAG,       3, , , , , ,       3
SAVE
vsbv,1,3,,,keep
vsbv,4,2,,,keep
ET,1,SOLID187
SAVE
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2e2
MPDATA,PRXY,1,,0.46
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,300e-12
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,0.5e2
MPDATA,PRXY,2,,0.46
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,790e-12
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,3,,1.4e2
MPDATA,PRXY,3,,0.46
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,3,,730e-12
SAVE
/COM,ANSYS RELEASE 15.0    UP20131014       10:30:59    06/15/2019
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       1, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , ,       2
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       2, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , ,       3
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       3, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,2,1,5,ORDE,1
FITEM,2,32
SFA,P51X,1,PRES,0.0015
FLST,2,3,5,ORDE,2
FITEM,2,1
FITEM,2,-3
/GO
DA,P51X,UZ,
FINISH
/PREP7
SMRT,6
SMRT,6
SMRT,OFF
MSHAPE,1,3D
MSHKEY,0
FLST,5,3,6,ORDE,2
FITEM,5,1
FITEM,5,-3
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
/STATUS,SOLU
SOLVE
Zl1232140
原因:1)由于模型材料弹性模量很小,导致加载后模型变形太快,造成错误提示:节点出现大位移;
           2)感觉单位制有点问题,材料单位和载荷单位不一致,模型单位是mm,载荷单位应该是MPa,命令中加载的压力为375,那么就是375MPA,是不是不对?
建议:
1)打开大变形求解选项;
2)确认单位制是否统一。
2019年6月15日
评论 3 点赞 1
邹正刚
  首先请你对自己的问题做一个详细的介绍,说明你的具体模型以及使用的单位,所用材料及其性能数据 (包括单位),计算中出现了什么问题 (错误或警告信息,以及 output 窗口中的内容),最好发几个图片上来。
  从你的命令流来看,材料性能数据很低,不知是否单位的问题?如果你的模型的程度单位是 mm,那么弹性模量和密度的数值都太小了,而压力载荷 375  (MPa) 又太大了 (折合  3750 个大气压),按照你的材料数据,早就压垮了。
  另外,你的求解设置几乎没有,连计算终止时间也没有设置。可以先设置一些试试:
  用以下命令流替换你的命令流中最后一个命令 SOLVE
ANTYPE, 0             !  静力计算
NLGEOM,ON             !  打开大变形
LNSRCH,ON
outres,all,all         !  输出所有子步的结果
/GST, ON
ncnv,2
TREF,25
time, 1             !  计算终止时间
KBC,0               !  斜坡方式加载
AUTOTS,ON           !  打开自动时间步
nsubst,1000000,1e10, 2      !  设置时间子步
NEQIT,35,            !  最大迭代次数 35
CNVTOL,F, ,0.001,2,-1,       !  设置力收敛准则
ALLSEL,ALL
SOLVE
  替换以后,进行求解,估计前几个子步有可能收敛,但是最终还是不收敛。不过你可以到后处理去看一下已经收敛的几个子步的结果,分析一下,可能是什么问题。
2019年6月17日
评论 2 点赞
