abaqus 材料属性怎么设置和时间相关?
浏览:3929 回答:2
我才接触CAE。一些基本功都不太懂。
我了解到通过Field Variable和Amplitude来实现。
首先我定义了一个幅值曲线:
*Amplitude, name=Amp-3
         86400.,              0.,         172800.,              1.,         259200.,              2.,         345600.,              3.
        518400.,              4.
然后在材料里面的弹性模量里面已经定义了和场变量Fv有关:
*Material, name=concrete
*Conductivity
 2.618,
*Density
 2497.77,
*Elastic, dependencies=1
 2.69e+10, 0.2, ,  0.
 3.21e+10, 0.2, ,  1.
 3.53e+10, 0.2, ,  2.
 3.71e+10, 0.2, ,  3.
 3.71e+10, 0.2, ,  4.
后面我是在step-2里面加入Field Variable,可是我具体不知道怎么加进去。
** amplitude to change FV1 during the time
** field variable definition
*FIELD, VARIABLE=1, AMPLITUDE=Amp-3
可是在*Initial Conditions,里面需要定义field吗?
下面是我的部分inp文件。请大神帮我看一下。非常感谢了。
毕业好艰难。(┬_┬)
** PREDEFINED FIELDS
** Name: Predefined Field-1   Type: Temperature
*Initial Conditions, type=TEMPERATURE
_PickedSet37, 20.
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=302400
*Static, direct
1800., 518400.,
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field
*Node Output, exterior
CF, RF, RM, RT, TF, U, UR, UT
V, VF, VR, VT
*Element Output, exterior, directions=YES
ALPHA, ALPHAN, BF, CENTMAG, CENTRIFMAG, CORIOMAG, CS11, CTSHR, E, EE, ER, ESF1, GRAV, HP, IE, LE
MISES, MISESMAX, MISESONLY, NE, NFORC, NFORCSO, P, PE, PEEQ, PEEQMAX, PEEQT, PEMAG, PEQC, PRESSONLY, PS, ROTAMAG
S, SALPHA, SE, SEE, SEP, SEPE, SF, SPE, SSAVG, THE, TRIAX, TRNOR, TRSHR, TSHR, VE, VEEQ
VS
*Contact Output
CDISP, CDISPETOS, CDSTRESS, CFORCE, CLINELOAD, CNAREA, CPOINTLOAD, CSTATUS, CSTRESS, CSTRESSETOS, PPRESS
** HISTORY OUTPUT: H-Output-2
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
** STEP: Step-2
*Step, name=Step-2, nlgeom=YES, inc=302400
*Static, direct
1800., 518400.,
*AMPLITUDE, name=Amp-3
** BOUNDARY CONDITIONS
** Name: BC-1 Type: 位移/转角
*Boundary
Set-6, 1, 1
Set-6, 2, 2
Set-6, 3, 3
** Name: BC-2 Type: 位移/转角
*Boundary
Set-7, 1, 1
Set-7, 2, 2
** Name: Predefined Field-2   Type: Temperature
*Temperature, file=D:/Abaqus/Job-3.odb, bstep=1, binc=1, estep=1, einc=252, interpolate
** OUTPUT REQUESTS
** FIELD OUTPUT: F-Output-2
*Output, field
*Node Output
V, VF, VR, VT
*Element Output, directions=YES
VS
*Contact Output
V, VF, VR, VT
VS
*Contact Output
*End Step
林ads
你要设置的材料参数随时间变化对吧?
2017年3月1日
微信公众号:FILWTBY
我主页上有我的微信和邮箱,加我微信详聊
2017年2月28日
