仿真结果不满意???
浏览:2475 回答:6
仿真结果不满意???的图1
仿真结果不满意???的图2
仿真结果不满意???的图3
第二幅图,是工具头轨迹,可是第一第三幅应变图上,明显不是圆。在最初加工时显示都是圆,但是越往下走,圆就慢慢变成了类似菱形的样子,这是为什么???工具头轨迹是没有问题的,望大神指导。。。
轨迹导入采用的是amplitude-smooth step
** MATERIALS
*Material, name=Material-1
*Density
 2.7e-09,
*Elastic
71000., 0.34
*Plastic
 90.,      0.
131., 0.00159
171., 0.00649
211.,  0.0177
251.,  0.0395
291.,  0.0776
331.,   0.139
391.,   0.295
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-1
*Friction
 0.2,
*Surface Interaction, name=IntProp-2
*Friction
 0.1,
** BOUNDARY CONDITIONS
** Name: BC-2 Type: Displacement/Rotation
*Boundary
ban, 1, 1
ban, 2, 2
ban, 3, 3
ban, 4, 4
ban, 5, 5
ban, 6, 6
** Name: BC-3 Type: Displacement/Rotation
*Boundary
rfxiaban, 1, 1
rfxiaban, 2, 2
rfxiaban, 3, 3
rfxiaban, 4, 4
rfxiaban, 5, 5
rfxiaban, 6, 6
** Name: BC-X Type: Displacement/Rotation
*Boundary
rftool, 1, 1
** Name: BC-Y Type: Displacement/Rotation
*Boundary, amplitude=Amp-equallyY
rftool, 2, 2
** Name: BC-Z Type: Displacement/Rotation
*Boundary
rftool, 3, 3
** Name: BC-rftoolfix Type: Displacement/Rotation
*Boundary
rftool, 4, 4
rftool, 5, 5
** Name: BC-toolrotation Type: Velocity/Angular velocity
*Boundary, type=VELOCITY
rftool, 6, 6
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES
*Dynamic, Explicit
, 60.22
*Bulk Viscosity
0.06, 1.2
** Mass Scaling: Semi-Automatic
**               Whole Model
*Fixed Mass Scaling, factor=200.
*Boundary, op=NEW
ban, 1, 1
ban, 2, 2
ban, 3, 3
ban, 4, 4
ban, 5, 5
ban, 6, 6
*Boundary, op=NEW
rfxiaban, 1, 1
rfxiaban, 2, 2
rfxiaban, 3, 3
rfxiaban, 4, 4
rfxiaban, 5, 5
rfxiaban, 6, 6
*Boundary, op=NEW, amplitude=Amp-smoothX
rftool, 1, 1, 1.
*Boundary, op=NEW, amplitude=Amp-smoothY
rftool, 2, 2, 1.
*Boundary, op=NEW, amplitude=Amp-smoothZ
rftool, 3, 3, 1.
*Boundary, op=NEW
rftool, 4, 4
rftool, 5, 5
*Boundary, op=NEW, type=VELOCITY
rftool, 6, 6, 1000.
** INTERACTIONS
** Interaction: Int-1
*Contact Pair, interaction=IntProp-1, mechanical constraint=PENALTY, cpset=Int-1
Surf-tool, Surf-bantop
** Interaction: Int-2
*Contact Pair, interaction=IntProp-2, mechanical constraint=PENALTY, cpset=Int-2
Surf-xiaban, Surf-banbottom
** OUTPUT REQUESTS
*Restart, write, overlay, number interval=1, time marks=NO
** FIELD OUTPUT: F-Output-1
*Output, field, number interval=5000
*Node Output, nset=Part-3dplan-1.Set-ban
U,
*Element Output, elset=Part-3dplan-1.Set-ban, directions=YES
MISES, PE, PEEQ, S, STH
** FIELD OUTPUT: F-Output-2
*Node Output, nset=b_Set-tool
U, V
** HISTORY OUTPUT: H-Output-1
*Output, history, time interval=0.00669111
*Energy Output
ETOTAL,
** HISTORY OUTPUT: H-Output-2
*Element Output, elset=Set-banelement
STH,
** HISTORY OUTPUT: H-Output-3
*Node Output, nset=rftool
VR3,
*End Step
小月
把inp附上来,看看
2017年2月22日
评论 3 点赞
干货有限元
看着好像沙漏比较严重
2017年2月22日
