请问这个错误有没有好的解决办法?
浏览:3412 回答:2
There is not enough memory for the Sparse Matrix solver to proceed.Please increase the virtual memory on your system and/or increase the work space memory and rerun ANSYS.  Alternatively, forcing the use of the minimum out-of-core memory mode (BCSOPTION,,MINIMUM) may allow a solution to be achieved without increasing the system memory or decreasing the problem size.  The memory currently allocated by ANSYS = 684 MB. The memory allocation attempted = 298 MB. The largest block of ANSYS memory available for the Sparse Matrix solver = 121 MB.
宁博士CAE团队
第二种方法,增加虚拟内存:a,右击电脑-》属性;b,见下图,
c,还是不能解决,换硬件,增加内存条,换
2017年1月10日
宁博士CAE团队
有两种方法参考:第一,增大网格尺寸,用低阶单元,减小约束方程等等,减小计算规模
2017年1月10日
