这个abaqus错误信息提示,可视化中没有结果,element set ErrElemMissingSection需要怎么操作才能打开啊?
浏览:5260 回答:2
 ***ERROR: 4 elements have missing property definitions. The elements have been
           identified in element set ErrElemMissingSection.
 ***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
 ***WARNING: 4 elements have incorrect property definitions. The elements have
             been identified in element set WarnElemIncorrectProperty.
 ***ERROR: SECTION DEFINITIONS ARE MISSING OR INCORRECT FOR THE ELEMENTS
           INDICATED ABOVE. FURTHER PROCESSING OF THE INPUT FILE IS NOT
           POSSIBLE UNTIL THIS INPUT ERROR IS FIXED.
微信公众号:FILWTBY
要么是材料属性没有定义,要么定义错啦,材料属性和单元类型要一致
2017年1月5日
技术工
@victor007 @晓月清风_mi@君莫
2017年1月5日
