ansys求解时出现错误,求教各位
浏览:1902 回答:1
水中谐响应求解时出现如下错误:
property sons of material 4 referenced by element 1 was set to 0 which cannot be negative or extremely small.
property sons of material 3 referenced by element 76801 was set to 0 which cannot be negative or extremely small.
property sons of material 5 referenced by element 204001 was set to 0 which cannot be negative or extremely small.
其中材料3、4、5分别为近场水,远场水,边界水;不知是材料设置的问题还是网格划分的问题,还是什么其他问题??求大神给小弟指教,谢谢!!!
宁博士CAE团队
材料设置有问题,可能有些材料选项缺少设置,ansys自动默认为0,建议仔细检查材料
2016年11月8日
