新人求问大神一些问题
浏览:2145 回答:5
当我把宏文件导入到ANSYS后出现下面问题
附上宏文件命令:
/prep7
*del,all
cmsel,s,longgu_line
pai=3.1415926
e_tan=2.1e5
f_y=235
lmd_y=1.05
lmd_z=1.05
*get,lmin,line,0,num,min
*get,lnum,line,0,count
*get,lmax,line,0,num,max
ll=lmin
*dim,changxibi,,lunm,4
esll,s
*get,enum,elem,,count
*dim,result,,enum,2
*dim,result_la,,enum,2
*dim,result_ya,,enum,2
num_of_line=0
num_of_line_la=0
num_of_line_ya=0
num_of_ele=0
num_of_ele_la=0
num_of_ele_ya=0
*do,m,1,lnum,1
num_of_line=num_of_line+1
lsel,s,line,,ll,ll,1
*get,length_of_line,line,ll,leng
changxibi(num_of_line,4)=length_of_line
esll,s
/post1
etable,sdi,smisc,31
etable,sbi_yt,smisc,32
etable,sbi_yb,smisc,33
etable,sbi_zt,smisc,34
etable,sbi_zb,smisc,35
etable,axial_f,smisc,1
smax,sbi_y_max,sbi_yt,sbi_yb,1,1
smin,sbi_y_min,sbi_yt,sbi_yb,1,1
smax,sbi_z_max,sbi_zt,sbi_zb,1,1
smin,sbi_z_min,sbi_zt,sbi_zb,1,1
*get,emin,elem,0,num,min
*get,emax,elem,0,num,max
ee=emin
*get,sect_num,elem,ee,attr,secn
*get,area_sec,secp,sect_num,prop,area
*get,iz_sec,secp,sect_num,prop,izz
*get,iy_sec,secp,sect_num,prop,iyy
iyy=sqrt(iy_sec/area_sec)
izz=sqrt(iz_sec/area_sec)
lmd_cxb_y=length_of_line/iyy
lmd_cxb_z=length_of_line/izz
ne_y=(pai**2*e_tan*area_sec)/(1.1*lmd_cxb_y**2)
ne_z=(pai**2*e_tan*area_sec)/(1.1*lmd_cxb_z**2)
changxibi(num_of_line)=ll
lmd_cxb=lmd_cxb_y
*if,lmd_cxb_y,le,lmd_cxb_z,then
*endif
changxibi(num_of_line,2)=lmd_cxb
*get,str_zhou,elem,ee,etab,sdi,,,
*if,str_zhou,gt,1e-8,then
        mark=1
        changxibi(num_of_line,3)=1
        num_of_line_la=num_of_line_la+1
                   fai_wd=0
*elseif,str_zhou,lt,1e-8,then
        mark=2
        changxibi(num_of_line,3)=-1
        num_of_line_ya=num_of_line_ya+1
        lmd_n_y=(lmd_cxb_y/pai)*sqrt(f_y/e_tan)
        *if,lmd_n_y,le,0.215,then
                  fai_wd_y=1-0.65*lmd_n_y**2
        *elseif,lmd_n_y,gt,0.215,then
                  changshu=0.965+0.3*lmd_n_y+lmd_n_y**2
                  fai_wd_y=(changshu-sqrt(changshu**2-4*lmd_n_y**2))/(2*lmd_n_y**2)
        *endif
        lmd_n_z=(lmd_cxb_z/pai)*sqrt(f_y/e_tan)
        *if,lmd_n_z,le,0.215,then
                  fai_wd_z=1-0.65*lmd_n_z**2
        *elseif,lmd_n_z,gt,0.215,then
                  changshu=0.965+0.3*lmd_n_z+lmd_n_z**2
                  fai_wd_z=(changshu-sqrt(changshu**2-4*lmd_n_z**2))/(2*lmd_n_z**2)
        *endif
*endif
fai_wd=fai_wd_y
*if,fai_wd_z,le,fai_wd_y,then
fai_wd=fai_wd_z
*endif
changxibi(num_of_line,4)=fai_wd
*if,mark,eq,1,then
*do,n,1,enum,1
*get,stress_zhou,elem,ee,etab,sdi,,,
*get,stress_wq_y,elem,ee,etab,sbi_y_max,,,
*get,stress_wq_z,elem,ee,etab,sbi_z_max,,,
num_of_ele=num_of_ele+1
num_of_ele_la=num_of_ele_la+1
result(num_of_ele,1)=ee
result(num_of_ele,2)=(stress_zhou+sress_wq_y/lmd_y+sress_wq_z/lmd_z)
result_la(num_of_ele_la,1)=ee
result_la(num_of_ele_la,2)=(stress_zhou+sress_wq_y/lmd_y+sress_wq_z/lmd_z)
ee=elnext(ee)
*enddo
*elseif,mark,eq,2,then
*do,n,1,enum,1
*get,stress_wq_y,elem,ee,etab,sbi_y_min,,,
*get,stress_wq_z,elem,ee,etab,sbi_z_min,,,
*get,zhouli,elem,ee,etab,axial_f,,,
num_of_ele_ya=num_of_ele_ya+1
result(num_of_ele,2)=(stress_zhou/fai_wd+stress_wq_y/(lmd_y*(1.0-0.8*zhouli/ne_y))+stress_wq_z/(lmd_z*(1.0-0.8*zhouli/ne_z)))
result_ya(num_of_ele_ya,1)=ee
result_ya(num_of_ele_ya,2)=(stress_zhou/fai_wd+stress_wq_y/(lmd_y*(1.0-0.8*zhouli/ne_y))+stress_wq_z/(lmd_z*(1.0-0.8*zhouli/ne_z)))
ee=elnext(ee)
*enddo
*endif
cmsel,s,longgu_line
ll=lsnext(ll)
*enddo
大神们能帮我看看错在哪吗?改了好几天,依然毫无头绪!!!不胜感激啊!!
力争ANSYS大神
没有大神吗@ANSYS专家
2016年9月15日
评论 4 点赞
