浏览:1487 回答:1
急!!!ANSYS热分析施加坡形温度载荷,定义计算终止时间24.00001小时报错,跪求大神帮助!!!谢谢啦!!!错误警告及命令流如下: *** ERROR ***                           CP =    1818.703   TIME= 23:14:25 Present time 24.00001 is less than or equal to the previous time in a    transient analysis.                                      /COM,ANSYS RELEASE 12.0.1  UP20090415       22:39:54    07/03/2016 /POST1   !*   /EFACET,1    PLNSOL, TEMP,, 0 FINISH   /SOL FINISH   /PREP7   FLST,2,1,4,ORDE,1    FITEM,2,23   /GO  !*   SFL,P51X,CONV,19, ,-10,  FINISH   /SOL TIME,24.00001    LSWRITE,6,   FINISH   /PREP7   FLST,2,1,4,ORDE,1    FITEM,2,23   /GO  !*   SFL,P51X,CONV,19, ,50,   TOFFST,273   FINISH   /SOL TIME,26  LSWRITE,7,   FINISH   /PREP7   FLST,2,1,4,ORDE,1    FITEM,2,23   /GO  !*   SFL,P51X,CONV,19, ,50,   FINISH   /SOL TIME,32  LSWRITE,8,   FINISH   /PREP7   FLST,2,1,4,ORDE,1    FITEM,2,23   /GO  !*   SFL,P51X,CONV,19, ,-15,  FINISH   /SOL TIME,35  LSWRITE,9,   FINISH   /PREP7   FLST,2,1,4,ORDE,1    FITEM,2,23   /GO  !*   SFL,P51X,CONV,19, ,-15,  FINISH   /SOL TIME,48  LSWRITE,10,  LSSOLVE,1,10,1,  FINISH   /POST1   !*   /EFACET,1    PLNSOL, TEMP,, 0 SET,LAST SET,LAST FINISH   ! /EXIT,NOSAV @土木工程师千总
程杰
急求大神帮助!!!跪谢!!!
2016年7月15日
