32 nodes may not be used~~~
浏览:2031 回答:1
32 nodes may not be used with a multi-point constraint since they are also part of pretension section. The nodes have been identified in node set ErrNodeMPCPretenSec.请问这句话应该如何解决
Legal high
求大神指点
2016年6月21日
